Hi!
I have for my hobby new CGA2VGA converter. I'm displaying it on VGA output of my Neovo X-22 LCD, for my happy is there possible to select colors separately for each input. Really looks default color settings very bad.
When I'm capturing this output it's not possible by software correctly to solve color correction (using Movavi, Stream Catcher of PEXHDCAP).
So, I want to buy not precious color, brightness, saturation corrector and booster to display/capture it without manual changes.
Why?
When I switch to HDMI capturing with values set for VGA image is incorrect colored, so I must to manually adjust it and vice versa.
Can anybody recommend me any not too precious device?
This is default settings:
This is adjusted by capture software:
This is default corrected by NCH PhotoPad:
Name:	default ext.corr.jpg
This is adjusted by capture software and after corrected by NCH PhotoPad:
Name:	adjusted ext.corr.jpg
In all - you see colors and brightness with saturation... and when I switch to HDMI or vice versa it's only about adjusting and adjusting...
Neovo X-22 can correct colors perfectly but I want to sell it, so please help me.
Thank you for all.
Miro
