Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or buy Replay Video Capture or PlayON and record Netflix, HBO, etc! :)
    May 2007
    I want to make a video, and post it to facebook, where it loops over and over. How would i do this? Is it possible? i would imagine an avisynth script would work. Wouldn't it? I know there is a Loop () command. If someone would write the script, i'd appreciate it!
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    You can convert your video into an animated gif that loops forever, but you wont have audio.
  3. Member racer-x's Avatar
    Mar 2003
    You can loop a video with Avisynth, but you will need to tell it how many loops. Example to loop 5 times:
    DirectShowSource("path\to\your.mp4")
    Loop(5)
    Feb 2004
    Australia
    Facebook does not supported animated gif's thou Giphy url links work but it's specialized, normal url links to animated gif's will most likely be flattened to a single image via facebooks own code.
    May 2007
    Thanks for the help, guys. Unfortunately, facebook doesn't accept animated gifs. I made my video, and it's looping fine. Too bad i can't upload it to facebook. I have seen looped videos on facebook before, but they're probably from tv news, and somehow they managed to upload them.
  6. There are workaround to put animated gifs on facebook. Use google, there are many tutorials on this subjet
