  1. Hi. I have a problem with videos in Adobe Premiere Pro cs6. some frames of videos are checkered but in windows when i play video with a player like MPC, it has't any problem.
    one frame for sample :
    First in MPC and second in PR:
Name:	Tinker Bell Secret .jpg
    What is the problem ?!
  2. Probably format or encoding settings used not supported (Adobe doesn't support everything) . If I had to guess this is h.264 using some settings that are not supported
    What does mediainfo (view=>text) say about the file ?
  3. Originally Posted by poisondeathray View Post
    this video is encoded with Ripbot 18.0 (I recently update ripbot to new version)
    mediainfo :
    \Animations\Secret wings\Tinker Bell Secret of The Wings 2012 Bluray 1080p.mp4
    Format profile                           : Base Media
    Codec ID                                 : isom
    File size                                : 159 MiB
    Duration                                 : 1h 15mn
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 296 Kbps
    Encoded date                             : UTC 2014-10-23 21:41:46
    Tagged date                              : UTC 2014-10-23 21:41:46
    Video
    Format profile                           : High 10@L3.1
    Format settings, ReFrames                : 5 frames
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Duration                                 : 1h 15mn
    Bit rate mode                            : Variable
    Bit rate                                 : 230 Kbps
    Maximum bit rate                         : 17.5 Mbps
    Width                                    : 960 pixels
    Height                                   : 540 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Bit depth                                : 10 bits
    Bits/(Pixel*Frame)                       : 0.019
    Stream size                              : 123 MiB (77%)
    Title                                    : Tinker Bell Secret of The Wings 2012 Bluray 1080p
    Writing library                          : x264 core 142 r2479 dd79a61
    Encoding settings                        : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=230 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=17500 / vbv_bufsize=17500 / nal_hrd=vbr / filler=0 / ip_ratio=1.40 / aq=1:1.00
    Tagged date                              : UTC 2014-10-23 21:41:53
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : HE-AAC / LC
    Codec ID                                 : 40
    Duration                                 : 1h 15mn
    Bit rate                                 : 64.0 Kbps
    Maximum bit rate                         : 70.6 Kbps
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 KHz / 24.0 KHz
    Stream size                              : 34.4 MiB (22%)
    Language                                 : English
    Encoded date                             : UTC 2014-10-23 21:41:52
    Menu
    00:00:00.000                             : 00:00:00.000
    00:05:53.019                             : 00:05:53.019
    00:09:04.627                             : 00:09:04.627
    00:14:10.516                             : 00:14:10.516
    00:20:32.481                             : 00:20:32.481
    00:28:17.404                             : 00:28:17.404
    00:34:46.209                             : 00:34:46.209
    00:40:26.466                             : 00:40:26.466
    00:48:07.134                             : 00:48:07.134
    00:53:50.686                             : 00:53:50.686
    01:00:37.175                             : 01:00:37.175
    01:07:47.563                             : 01:07:47.563
  4. Format profile : High 10@L3.1
    The 10bit variant of AVC is only supported in a limited fashion by Adobe through AVC-Intra (Panasonic's implementation).
    If you want to edit in Adobe, use the original BD source
    (Quality is terrible there @ 230kbps , and it will only get worse if you edit that crappy version)
  5. Thanks very much. I will change High 10 to High in Ripbot Profile.
