Program that takes wtv-files including subtitles and converts them into mp4 or mkv.
WTV2TV
WTV2TV is a wtv converter.
It converts wtv-files to mp4 or mkv
To mp4 in case there are no subtitles in the wtv_file or if you wish the subtitles to be burned in.
The mkv format is used for embedded subtitles.
Subtitles are dvb-subtitles present in the wtv-file.
It takes al the wtv-files which are stored in same folder as WTV2TV and converts them.
(batch)
It produces videos in excelent quality in the same resolution as the imput-file
WTV2TV uses FFMPEG and MKVExtract which needed to be seperatly downloaded.
The package contains 3 files: WTV2TV.exe, a small dat file, Agree.dat.
Both need to be placed in the same folder where you keep your WTV-files.
The third file is this HTML-file
An instuction-video how to setup and run WTV2TV can be found her:
My website:
You can contact me : bonnevue@live.nl
SEE MY LATEST POST FOR UPDATED EN NEW FILES, PLEASE DOWNLOAD FROM THAT POST
I did the same for converting ts and trp files. Please pick one from this post and ignore the attachment in my pervious post
