not too complicated, possibly: I'm a cat! ^^
You don't need a plugin - the standard AssumeFPS(), AssumeScaledFPS(), ChangeFPS() and ConvertFPS() internal filters all can do that with YUY2.
Hope that's not too complicated for you.
Scott -
for example if I have a progressive sources 48fps or 60 fps or 30fps that I whould convert to 25i, that is the proper procedure to do that? is necessary a motion interpolation?
Depends on what LOOK you want to give it. Could be done as PsF, could be done by losing alternate lines, could be done with pull-up/down and or slow-up/down. With or without interpolation again depends on your intended outcome.
But don't expect ANY of those looks to be identical to your source.
