Hello
I am trying to convert a film I have on BluRay to MKV.
I have ripped the BluRay to my HDD and I can play it in VLC.
I have tried MakeMKV and it basically hangs, its never gets to the end and just appears to go on for ever. In the past I have really enjoyed using MakeMKV and it has never failed me. I am using MakeMKV version 1.8.14.
Next I tried tsMuxer and mkvMerge. I used tsMuxer to demux, this created a .264 file, .ac3 and .sup. I then used mkvMergeGUI to create the final MKV.
The final MKV when played is full of artefacts, screen corruption and intermittant sound - unwatchable.
I am now trying BDHero, but I suspect I will get the same problem
For Info :
The source BluRay is H.264 1080p / 23.976 with Dolby TrueHD 7.1
Any help will really really be appreciated.
M
	What did you rip with?I have ripped the BluRay to my HDD and I can play it in VLC.
 I think you can add blu-ray m2ts files or blu-ray playlists directly in mkvtoolnix / mkvmergegui. No need for tsmuxer.
	Be happy you found a solution that worked. Sometimes one tool fails and another works. It just happens like that sometimes. "The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
