Hi,
I just wanted to ask if anybody can recreate these issues. I'd like to watch the HD streams of this year's iTunes Festival directly over the Apple TV 3 (not AirPlay) and it doesn't matter what I select (1080p with 50 or 60 Hz) there is always slight stuttering noticeable from time to time, especially when the camera is panning over die audience.
Since the concerts have been recorded in England I thought 50 Hz would be the correct setting but something always seems to be off.
It doesn't matter whether I directly connect the ATV to my Panasonic TV or have a VP between the two (my normal setup with an old DVDO VP50 Pro).
The TV can handle 23.976/50/59.94 Hz properly, if I use a Blu-ray player with the ATV's HDMI cable to watch discs that are encoded with 1080p23.976, 1080p25 or 1080p29.97 everthing is smooth.
I've reset all devices to factory defaults a couple of time but no change there.
Advice would be greatly appreciated. Can anybody tell with certainty what fps setting is used with these streams? At least then I could set the hardware properly and check for further configuration errors.
Thanks!
Results 1 to 1 of 1
