Results 1 to 9 of 9
    Jan 2011
    Canada
    It's an avi. Open in VDub. Full Processing mode. Interleaving > adjust stew correction up and down between + or -ten, doesn't make a difference in playback within VDub. Do I have to save it to see the difference? Audio is lagging behind video.
    Dec 2005
    Canada
    I find that plus or minus 200 is a good place to start with some over the air recordings.
    Jan 2011
    Canada
    Tried "+200 ms" and made no difference for playback in VDub. Do I have to save it first to see the difference? Audio lagging behind video.
    Jan 2011
    Canada
    4 hours ETA now at 13% at full processing mode at +300 ms to see if it works. Sure would like to know if there's an easier way.
    Jan 2011
    Canada
    Just checked the avi dub in progress, same out-of-sync. Anyone able to offer suggestions here?
  6. Originally Posted by shokan22 View Post
    Play the original AVI in a player that can adjust the audio synch on-the-fly. I use MPC-HC. Figure out the delay and then adjust the audio skew in VDub. Don't do your testing in VDub.
    Use Direct Stream Copy for the video.
    Jan 2011
    Canada
    Thanks. I found a version that's synced well, but I'll save your info.
  8. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Make sure you are testing a video AFTER is it converted (Potplayer will play partially converted videos) because it may just SOUND like it is out of sync depending on the speed of your computer trying to keep up with many filters in use in virtualdub. Try it just with audio adjust only first. If you are using other filters, disable for test.
  9. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    ms = milliseconds.....MILLI.
