Results 1 to 16 of 16
  1. Member logicom's Avatar
    Oct 2008
    Serbia
    I have been capturing the content from sony DVCAM tape device using firewire and enosoft dv processor.
    DVCAM was set to record 4 audio chanels at 32Khz 12bit, so the tape/media was recorded this way.
    Upon copying the content/capturing, I got as two sets of stereo channel
    Inside DV container, there was a DV25 video stream and 2 audio streams each containing 1 stereo channel.
    Format                                   : DV
    File size                                : 743 MiB
    Duration                                 : 3mn 36s
    Overall bit rate mode                    : Constant
    Overall bit rate                         : 28.8 Mbps
    Video
    Format                                   : DV
    Duration                                 : 3mn 36s
    Bit rate mode                            : Constant
    Bit rate                                 : 24.4 Mbps
    Width                                    : 720 pixels
    Height                                   : 576 pixels
    Display aspect ratio                     : 4:3
    Frame rate mode                          : Constant
    Frame rate                               : 25.000 fps
    Standard                                 : PAL
    Scan type                                : Interlaced
    Scan order                               : Bottom Field First
    Bits/(Pixel*Frame)                       : 2.357
    Stream size                              : 630 MiB (85%)
    Audio #1
    Format                                   : PCM
    Duration                                 : 3mn 36s
    Bit rate                                 : 768 Kbps
    Encoded bit rate                         : 0 bps
    Sampling rate                            : 32.0 KHz
    Bit depth                                : 12 bits
    Stream size                              : 19.8 MiB (3%)
    Audio #2
    Format                                   : PCM
    Duration                                 : 3mn 36s
    Bit rate                                 : 768 Kbps
    Bit depth                                : 12 bits
    My goal is to get all this wrapped into .MOV container with four separate audio channels, by splitting two stereo streams into four separate mono or four separate double mono audio streams, and without using NLE software, but preferably ffmpeg command line or something similar, and on windows OS.
    First I try just to extract existing audio streams with ffmpeg and ffmbc like this:
    ffmpeg -i input.dv -filter_complex channelsplit out.mka
    the problem is that only first audio stream is being processed while there is an error accessing the second.
    Just to mention that the input file is not corrupted but I am able to play and select and hear audio streams correctly (two by two)
    Input #0, dv, from 'TEST_21102014_RAWDV.dv':
      Metadata:
        timecode        : 20:15:48:23
      Duration: 00:03:36.36, start: 0.000000, bitrate: 28800 kb/s
        Stream #0:0: Video: dvvideo, yuv420p, 720x576 [SAR 16:15 DAR 4:3], 28800 kb/s, 25 fps, 25 tbr, 25 tbn, 25 tbc
        Stream #0:1: Audio: pcm_s16le, 32000 Hz, stereo, s16, 1024 kb/s
        Stream #0:2: Audio: pcm_s16le, 32000 Hz, stereo, s16, 1024 kb/s
    Output #0, matroska, to 'out.mka':
      Metadata:
        encoder         : Lavf56.9.101
        Stream #0:0: Audio: vorbis (libvorbis) (oV[0][0] / 0x566F), 32000 Hz, 1 channels (FL), fltp
        Metadata:
          encoder         : Lavc56.8.102 libvorbis
        Stream #0:1: Audio: vorbis (libvorbis) (oV[0][0] / 0x566F), 32000 Hz, 1 channels (FR), fltp
        Metadata:
    Stream mapping:
      Stream #0:1 (pcm_s16le) -> channelsplit
      channelsplit:FL -> Stream #0:0 (libvorbis)
      channelsplit:FR -> Stream #0:1 (libvorbis)
    Press [q] to stop, [?] for help
    TEST_21102014_RAWDV.dv: Input/output error129.3kbits/s
    size=    3420kB time=00:03:36.35 bitrate= 129.5kbits/s
    video:0kB audio:3277kB subtitle:0kB other streams:0kB global headers:6kB muxing overhead: 4.356943%
    First I try to extract each channel of an input to specific output like:
    ffmpeg -i input.dv -map_channel 0.1.0 OUTPUT_CH0.mka -map_channel 0.1.1 OUTPUT_CH1.mka
    so I got first stream as two separate channels in separate files, again with the notification about the Input/output error.
    Input #0, dv, from 'input_RAWDV.dv':
      Metadata:
    File 'OUTPUT_CH0.mka' already exists. Overwrite ? [y/N] y
    File 'OUTPUT_CH1.mka' already exists. Overwrite ? [y/N] y
    -map_channel is forwarded to lavfi similarly to -af pan=0x4:c0=c0.
    [pan @ 02b603e0] This syntax is deprecated. Use '|' to separate the list items.
    [pan @ 02b603e0] Pure channel mapping detected: 0
    -map_channel is forwarded to lavfi similarly to -af pan=0x4:c0=c1.
    [pan @ 02c6cea0] This syntax is deprecated. Use '|' to separate the list items.
    [pan @ 02c6cea0] Pure channel mapping detected: 1
    Output #0, matroska, to 'OUTPUT_CH0.mka':
      Metadata:
        Stream #0:0: Audio: vorbis (libvorbis) (oV[0][0] / 0x566F), 32000 Hz, mono, fltp
        Metadata:
    Output #1, matroska, to 'OUTPUT_CH1.mka':
      Metadata:
        Stream #1:0: Audio: vorbis (libvorbis) (oV[0][0] / 0x566F), 32000 Hz, mono, fltp
        Metadata:
    Stream mapping:
      Stream #0:1 -> #0:0 (pcm_s16le (native) -> vorbis (libvorbis))
      Stream #0:1 -> #1:0 (pcm_s16le (native) -> vorbis (libvorbis))
    input_RAWDV.dv: Input/output error 65.0kbits/s
    size=    1719kB time=00:03:36.35 bitrate=  65.1kbits/s
    I was able to send output to wav as well, but I couldn't ever get channel 3 and 4 as separate due to the fact that stream 2
    for some reason is not accessible from original file, so with this:
    ffmpeg -i input_RAWDV.dv -map_channel 0.2.0 OUTPUT_CH3.mka -map_channel 0.2.1 OUTPUT_CH4.mka
    result was original stream 1 output in both files.
    There is also a method with panning but since I couldn't reach stream 2 I didn't try that.
    Any suggestion on how to get raw DV with two stereo audio streams rewrapped into .MOV container with four separate audio streams/channels?
    Thanks!
  2. It's a bit weird in ffmpegland, but you need to specify -map for each time you call an input stream, and -map_channel explicitly for each input and output filetream:channel . That's the reason why you couldn't access the 2nd audio stream or 0:2 (you didn't have a -map 0:2). So if you had 5 streams you want output (1 video, 4 mono audio) , you would need 5 -map commands, and 4 map_channel commands
    ffmpeg -i input.avi -map 0:0 -map 0:1 -map 0:1 -map 0:2 -map 0:2 -c:v copy -c:a copy -map_channel 0.1.0:0.1 -map_channel 0.1.1:0.2 -map_channel 0.2.0:0.3 -map_channel 0.2.1:0.4 output.mov
    Stream #0:0: Video: dvvideo, yuv411p, 720x480 [SAR 8:9 DAR 4:3], 28771 kb/s,
    29.97 fps, 29.97 tbr, 29.97 tbn, 29.97 tbc
    Output #0, mov, to 'out.mov':
    Metadata:
    encoder : Lavf56.0.100
    Stream #0:0: Video: dvvideo (dvcp / 0x70637664), yuv411p, 720x480 [SAR 8:9 D
    AR 4:3], q=2-31, 28771 kb/s, 29.97 fps, 30k tbn, 29.97 tbc
    Stream #0:1: Audio: pcm_s16le (sowt / 0x74776F73), 32000 Hz, stereo, 1024 kb
    /s
    Stream #0:2: Audio: pcm_s16le (sowt / 0x74776F73), 32000 Hz, stereo, 1024 kb
    /s
    Stream #0:3: Audio: pcm_s16le (sowt / 0x74776F73), 32000 Hz, stereo, 1024 kb
    /s
    Stream #0:4: Audio: pcm_s16le (sowt / 0x74776F73), 32000 Hz, stereo, 1024 kb
    /s
    Stream mapping:
    Stream #0:0 -> #0:0 (copy)
    Stream #0:1 -> #0:1 (copy)
    Stream #0:1 -> #0:2 (copy)
    Stream #0:2 -> #0:3 (copy)
    Stream #0:2 -> #0:4 (copy)
    Seems to work ok here on a sample with similar specs (but NTSC, not PAL DV). If it doesn't for you, it migth be that your files are slightly different, then post a small sample (direct stream copy video & audio in vdub)
  3. Member logicom's Avatar
    Oct 2008
    Serbia
    all right thanks!
    could you please assist me now with panning because I am getting 4 channels while first two are copy of original stream 0:1 and second two as copy of stream 0:2. So how I could incorporate panning - something like this:
    -filter_complex "[0:1]pan=1:c0=c0[left1];[0:1]pan=1:c0=c1[right1]"
    into the previous command in order to get 4 channels separated
    by the content.
    Regards.
  4. Open up the original in audacity or audio editor and look at the waveform. Chances are the L+R are identical in the source for each audio track
  5. Member logicom's Avatar
    Oct 2008
    Serbia
    Hi,
    that is not the case, waveforms are different as there are four different languages recorded on each channel. Sony DVCAM can record 4 separate tracks at 32Khz 12bit, but those 4 channels are organized as two sets of stereo, therefore I have to use pan feature now to detach those and remux them separately. I manage to do it with "FOCUS HD File Converter Pro", and rewrap to MOV without re-transcoding but this tool is not as good (I get double speed video/ 50frames/sec at playout) as ffmpeg so I would like to stick with ffmpeg.
    Regards.
  6. Post a short sample and I'll have a look at it later
  7. Member logicom's Avatar
    Oct 2008
    Serbia
    Hi,
    Sorry but that wouldn't be convenient, due to the ownership of this material.
    I would simply have to figure out ffmpeg command line, or someone might help with it's formulation for this particular task.
    Regards.
  8. You're right, I looked closer, the previous code didn't work
    So apparently -acodec copy (or -c:a copy) won't work for this with ffmpeg. You would need to up to 16bit
    Try ffmbc , this should work:
    ffmbc -i input.dv -vcodec copy -an output.mov -acodec pcm_s16le -newaudio -map_audio_channel 0:1:0:0:1:0 -acodec pcm_s16le -newaudio -map_audio_channel 0:1:1:0:2:0 -acodec pcm_s16le -newaudio -map_audio_channel 0:2:0:0:3:0 -acodec pcm_s16le -newaudio -map_audio_channel 0:2:1:0:4:0
    If it still doesn't work properly then you can break it out into steps with a ffmpeg / ffmbc batch file
  9. Member Cornucopia's Avatar
    Is the fact that those DV streams are 12bit and may not be parsed correctly (as there is no "pcm_s12le" option in ffmpeg) a complicating factor?
    For this problem, however, I think I would open the file in an NLE that is known to work correctly with 4ch 12bit 32kHz LPCM DV audio, such as PremierePro or the other pro NLEs. Then convert to 16bit 48kHz LPCM x 4 mono channels - it will be much more workable in that form.
  10. ^ Yes, that is why -acodec copy or -c:a copy didn't work.
    But that last code with ffmbc should work because it uses 16bit "-acodec pcm_s16le". I made a fake dual stereo file to test , with different channel waveforms (so easily examined in an audio editor) and it worked ok
  11. Member logicom's Avatar
    Oct 2008
    Serbia
    Hi,
    this worked with ffmbc.
    Thaks!
  12. Member logicom's Avatar
    Oct 2008
    Serbia
    But,
    there is a problem with lipsync, once I play .dv file it is perfect, but in mov audio is going ahead in relation to picture for around 150-200msec
    Is there anything that can be done in respect to the timecode, beacose simply creating newaudio and appending doesnt work well? and there mus not be second pass with -itsoffset beacose this is to rigid. So question is how to maintain perfect sync in mov as it is in .dv file, but to map the channels as separate?
    Regards.
  13. I don't know; I don't have an authentic sample to play with , that is long enough to test sync
    Did you try the ffmpeg version, just changing -c:a copy to c:a pcm_s16le?
    Stream mapping works fine (recall that the issue was 12bit PCM, which ffmpeg/ffmbc doesn't have a native implementation for, so can't be "copied"), but I can't properly test sync
    ffmpeg -i input.dv -map 0:0 -map 0:1 -map 0:1 -map 0:2 -map 0:2 -c:v copy -c:a pcm_s16le -map_channel 0.1.0:0.1 -map_channel 0.1.1:0.2 -map_channel 0.2.0:0.3 -map_channel 0.2.1:0.4 output2.mov
  14. Member logicom's Avatar
    Oct 2008
    Serbia
    Hi,
    yes I did try, but I have got the same resault with the ffmpeg or ffmbc on longer samples 1.5hour aprox. and a/v sync is not there - drifted
    One of the outputs I made was/is better in sync (less drift) but I did that one with soxr invoked
    ffmpeg -i output.dv -map 0:0 -map 0:1 -map 0:1 -map 0:2 -map 0:2 -c:v copy -af "aformat=sample_fmts=fltp,aresample=resampler=soxr:osr=44100:dither_method=0" -acodec pcm_s16le -map_channel 0.1.0:0.1 -map_channel 0.1.1:0.2 -map_channel 0.2.0:0.3 -map_channel 0.2.1:0.4 output.mov
    I am not sure, how to make perfect sync as it is on original .dv file, it seems like a muxer problem ?
    Regards.
  15. Member logicom's Avatar
    Oct 2008
    Serbia
    Hi,
    would it be wise to use Libswresample library with the similar arguments :
    -filter:a aresample=48000:async=1:min_comp=0.01:comp_duration=1:max_soft_comp=256000000:min_hard_comp=0.1
    maybe I misunderstood max_soft_comp but I put number which reflects maximum expected a/v length expressed in audio frames?
    as it is stated in documentation:
    -async samples_per_second
    Audio sync method. "Stretches/squeezes" the audio stream to match the timestamps, the parameter is the maximum samples per second by which the audio is changed. -async 1 is a special case where only the start of the audio stream is corrected without any later correction.
    Just from curiosity how it would be to use async option on a different way, maybe value in frames for one sec, or value as the frequency the alignment occurrence per segment ? How does this correlates with comp_duration value ?
    How about influencing muxer in AVFormatContext by reducing max_delay integer or no-buffer option?
    Could someone assist on this please?
    Regards.
  16. I don't know what those audio functions do exactly, but I suggest you open a new thread dedicated to that, otherwise some that *does* know, might miss it
