I am trying to encode the movie for my tablet from blu ray source.
At first I was using MakeMKV but that did not work so I tried DVDFab to rip it into a MKV, I want to encode it to mp4@7000KBps for my tablet.
I then used TSmuxer and found out that there were actually two video streams, one @ 1920x1080p which is the one I want and another one @720x480 which I don't want. My tablet can play full HiDef so the first stream I want to keep and encode.
The problem is no matter what I try the output video refuses to play in VLC.
I have tried remuxing the video into just the 1920 and then encoding but so far the exact same thing happens. The original plays fine on my computer. It is Cinavia protected if that makes a difference.
I want to be able to encode it @ h.264 Level 5.2 as files encoded with this version of the codec look really good even though they are onle 7000 Kbps.
Should I be using something other that Handbrake(it is what I am used to)?
And if so what?
What am I doing wrong that I can't play the video(even on my computer?
Results 1 to 16 of 16
MakeMKV should be able to decrypt and rip the movie. Try using the Backup mode to get the entire thing onto the hard drive. If this fails, use DVDFab to rip (ONLY RIP...NOT Re-encode).
Then use ClownBD to get the main movie into a separate Blu-ray structure. This new Blu-ray should work fine as input into Handbrake or VidCoder.
Level 5.2 is not necessary for a conversion for a tablet. You should use 4.0 or 4.1 at most. -
I did just that, I tried striping out the 720x480 stream and encoding in handbrake. I've tried encoding the m2ts. Nothing works. the original m2ts plays fine in VLC. I have tried encoding from mkv, I have not tried VidCoder so I will try that now. Wish me luck and thank you all for trying to help me.
If you rip the Blu-ray in its entirety, either using MakeMKV in Backup mode or with DVDFab, you should have a complete copy on the hard drive minus encryption. ClownBD should be able to pick out the correct main movie and give you a second copy in Blu-ray format, or as an m2ts file, this time without any extraneous audio or video streams since you can delete them in ClownBD if they show up in the lists. I don't remember ClownBD ever messing this up.
And this particular movie brings up no results when searching for problems at the Slysoft forums, so I have to think it does not have a particularly nasty protection scheme, like multiple mpls files that are almost, but not quite correct.
The second copy from ClownBD should play correctly, and should work in Handbrake or VidCoder. There isn't much difference between those two programs by the way. VidCoder is basically just a different GUI for Handbrake, with a few more options. -
I am trying clown now-it keeps giving me latest java runtime required and I just installed it not ten minuets ago.
Clown makes it look as if it is doing something but the output file still can not be played.
Here is the information from MediaInfo:
General
Complete name : F:\Video\backup\STREAM\50201.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 28.3 GiB
Duration : 1h 43mn
Overall bit rate : 39.3 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video #1
Menu ID : 1 (0x1)
Format : VC-1
Format profile : Advanced@L3
Codec ID : 234
Duration : 1h 43mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Video #2
Menu ID : 1 (0x1)
Format : VC-1
Format profile : Advanced@L2
Codec ID : 234
Duration : 1h 43mn
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Audio #1
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Muxing mode : Stream extension
Codec ID : 134
Duration : 1h 43mn
Bit rate mode : Variable
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Audio #2
Menu ID : 1 (0x1)
Format : DTS
Mode : 16
Codec ID : 130
Duration : 1h 43mn
Bit rate mode : Constant
Bit rate : 768 Kbps
Bit depth : 24 bits
Stream size : 566 MiB (2%)
Audio #3
Menu ID : 1 (0x1)
Format : DTS
Mode : 16
Codec ID : 130
Duration : 1h 43mn
Bit rate : 768 Kbps
Bit depth : 24 bits
Audio #4
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Format profile : Dolby Digital
Codec ID : 129
Duration : 1h 43mn
Bit rate : 192 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 141 MiB (0%)
Audio #5
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 43mn
Bit rate : 192 Kbps
Bit depth : 16 bits
Audio #6
Menu ID : 1 (0x1)
Format : DTS
Format profile : Express
Mode : 16
Codec ID : 162
Duration : 1h 43mn
Bit rate : 192 Kbps
Bit depth : 24 bits
Text #1
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #2
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #3
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #4
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #5
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
This is for the untouched blu ray rip.Last edited by BirdDaddie; 1st Feb 2018 at 01:16.
Don't know exactly, but 23.976fps 720x480 progressive video is not valid for VC-1 encoded BluRay, according to specs I've seen. Some encoders won't go for it. High bitrate MPEG for BluRay will if it's 23.97 + 3:2 pulldown to get it up to 29.976. That's the way it works with two of my encoders.
- My sister Ann's brother
