Adobe Premiere Pro apparently doesn't accept .ts files. I've got one I need to use; what's the best program/format to convert it to? I've had a play around with MediaCoder, which turned up in a search result on the subject, but it claims the file is 15 minutes long, when it's actually around 140, and gave me an error when I tried to convert to HuffYUV anyway (which I figured, being lossless codec, was a decent choice).
Are you asking because you think the issue might be file-specific? My research indicated that .ts simply isn't supported. It's worked fine in VLC and Media Player Classic.
If you think it might be file-specific, here's the MediaInfo:
General
Format : BDAV
Format/Info : Blu-ray Video
File size : 8.55 GiB
Duration : 2h 20mn
Overall bit rate : 8 728 Kbps
Video
Menu ID : 1665 (0x681)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Codec ID : 2
Duration : 2h 20mn
Bit rate mode : Variable
Bit rate : 7 924 Kbps
Maximum bit rate : 80.0 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
ActiveFormatDescription : Full frame 16:9 image
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.204
Stream size : 7.76 GiB (91%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 6
Duration : 2h 20mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -1s 56ms
Stream size : 449 MiB (5%)
Language : English
Text
ID : 577 (0x241)-801
Format : Teletext Subtitle
Language : English
Menu
List : 514 (0x202) (MPEG Video) / 577 (0x241) () / 672 (0x2A0) (AC-3, English)
Language : / / English -
I would run it through ProjectX and demux into video, audio and subs (on page 801), This has the advantage of cleaning up the file of any errors. You could then load the video and audio into Premiere.
If you haven't installed ProjectX an easy way to set it up is to just overwrite the default X.ini file found in the installation folder with the settings that follow. This will amongst other things name the video as .mpv and the audio .mpa but you can change this to suit your requirements.
ProjectX is available for PC, MAC and Linux
Code:# Project-X INI # ProjectX # Application Application.ActiveDirectory= Application.Agreement=1 Application.Language=en # AudioPanel AudioPanel.fillGapsWithLastFrame=1 # CollectionPanel CollectionPanel.CutMode=0 # ExportPanel ExportPanel.SplitSize=0 ExportPanel.SplitSize.Value=32 ExportPanel.Streamtype.Ac3Audio=1 ExportPanel.Streamtype.MpgAudio=1 ExportPanel.Streamtype.MpgVideo=1 ExportPanel.Streamtype.PcmAudio=1 ExportPanel.Streamtype.Subpicture=1 ExportPanel.Streamtype.Vbi=1 ExportPanel.createSubDirName=1 # ExternPanel ExternPanel.createCellTimes=0 ExternPanel.createChapters=1 ExternPanel.exportPts=1 ExternPanel.renameAudio=1 ExternPanel.renameVideo=1 # FtpServer FtpServer.Commands= # LogwindowPanel LogwindowPanel.showTtxHeader=1 # MainPanel MainPanel.ConversionMode=0 MainPanel.enablePostProcessing=1 MainPanel.useAllCollections=1 # MessagePanel MessagePanel.leadingTimeIndex=1 # NetPanel NetPanel.autostartWebServer=1 # OptionPanel OptionPanel.DebugLog=0 OptionPanel.ScanBuffer=2048000 OptionPanel.StartPath.Value= OptionPanel.additionalInputBuffer=1 # SpecialPanel SpecialPanel.TS.HeaderMode=0 SpecialPanel.TS.generateTtx=0 # SubtitlePanel SubtitlePanel.ChangeDisplay=0 SubtitlePanel.SubtitleExportFormat=SRT SubtitlePanel.SubtitleExportFormat_2=null SubtitlePanel.TtxExportBoxedOnly=0 SubtitlePanel.TtxPage1=801 SubtitlePanel.TtxPage2=null SubtitlePanel.TtxPage3=null SubtitlePanel.decodeHiddenRows=1 SubtitlePanel.decodeMegaradio=0 SubtitlePanel.exportAsVobSub=0 SubtitlePanel.exportTextAsUTF8=0 SubtitlePanel.exportTextAsUnicode=0 SubtitlePanel.keepOriginalTimecode=1 SubtitlePanel.rebuildPTS=1 # VideoPanel VideoPanel.ChangeBitrateInFirstSequence=2 VideoPanel.patchToInterlaced=0 VideoPanel.patchToProgressive=0 # WindowPosition WindowPosition.Main.Height=995 WindowPosition.Main.Width=1497 WindowPosition.Main.X=82 WindowPosition.Main.Y=0
