Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Oct 2014
    Cairo,Egypt
    Hi,
    I'd like to know which program can help me to get the track of ( sound effects and the music ) from Ac3 & DTS audio from MKV video ?
    For example : I've an episode of Anime and I'd like to extract the SFX and music from this episode without the voice of the dubber.
    Note : I've a PC not a MAC
    I hope that you understood me
  2. You can use gMKVExtractGUI / MKVExtractGUI to extract the audio track(s) from the MKV. In case both music and dubber is on the same track you could use Audacity (with the FFMpeg plugin) to see if they are on separate channels and select the one(s) you want. In the case they are on the same channel(s) not possible.
    Oct 2014
    Cairo,Egypt
    Thank you
    But Is there any explain / lessons for these programs or the way of working out ?
