Hello
I have an old Cambridge Audio DVD recorder i would like to hook-up to a amp for the purpose of recording radio shows from a hi-fi separate FM Tuner.
I have hooked-up the input/output leads and i'm getting sound through, the problem i'm experiencing is when i press the record button, pause comes up on player display instead of recording.
Can anyone please help?
I think your recorder needs to detect a video signal coming in to record.
wake up this planet is dying! -
I have 2 Panasonic dvd recorders and 1 Panasonic blu ray recorder. I know that the above is true for the Pannys.
I'm not sure if this applies to your Cambridge. Try connecting a video source to the video input and your tuner to the audio input and try recording.
Hopefully that will solve it.wake up this planet is dying! -
To clarify connect your tuner via your amp as you have already done.
