Having a bit of an issue here. I have TS files I am looking to author as blu-rays but TMPGEnc isn't cooperating.
The files:
1080i TS files, h264, direct unencrypted recordings from satellite TV. Completely compliant (i.e. shows "smart render" in the project) and many similar files convert without issue. a couple are buggy for whatever reason and I'm trying to figure out why.
Source files play fine in any media player (GOM, VLC for example).
M2TS files from BD output stutter in VLC and on-disc they appear to play in "slow motion" on my PS3. I know VLC is picky with HD stuff at times but I've authored countless projects from similar sources, and VLC has been able to play them flawlessly (my PS3 as well).
I've tested these with GOM Player and it handles them just fine. But it's not up to snuff for standard BD players so I'm trying to figure out how I can prepare these files.
Various experiments have been done...
I've tried running the files through multivachd, outputting a blu-ray with that, and then feeding that output into tmpgenc. multivachd's output does not stutter, but after tmpgenc is through with it, it does. So a proper working BD from that footage (without re-encoding) is possible, just not through tmpgenc apparently. So I'm trying to figure out what I can do to fix the file to make it tmpgenc-friendly, so to speak.
Another thing I have tested is full re-encodes. Once using Adobe Encore and once using Tmpgenc Video Mastering Works. Both outputs are useable, but as I'm not looking to re-encode, it was just to test and be sure the sources are fine and usable.
I've demuxed, converted the audio to AC3, remuxed, as well.. No luck. I've run it through VideoRedo's QuickStream Fix, no luck.
So...any ideas what can I can try next as a preparation for these files before authoring?
Thank you.
Original:
Format : MPEG-TS
File size : 10.7 GiB
Duration : 2h 46mn
Overall bit rate : 9 189 Kbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=4, N=28
Codec ID : 27
Duration : 2h 46mn
Bit rate mode : Variable
Maximum bit rate : 20.0 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Menu ID : 1 (0x1)
Format : AAC
Format version : Version 2
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Duration : 2h 46mn
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
AC3 audio via ffmpeg but still not working:
Format : MPEG-TS
File size : 11.3 GiB
Duration : 2h 46mn
Overall bit rate : 9 718 Kbps
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 2h 46mn
Bit rate : 9 011 Kbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.193
Stream size : 10.5 GiB (93%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 129
Duration : 2h 46mn
Bit rate mode : Constant
Bit rate : 224 Kbps
Bit depth : 16 bits
Delay relative to video : -5ms
Stream size : 267 MiB (2%)
Menu
Menu ID : 1 (0x1)
Duration : 2h 46mn
List : 256 (0x100) (AVC) / 257 (0x101) (AC-3)
Service name : Service01
Service provider : FFmpeg
Service type : digital television
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 15 of 15
Is that recording off TV strictly interlaced or is it telecined movie source?
- My sister Ann's brother -
Interlaced AFAIK... but not 100% positive... would you suggest different things for each?
I may be way off base, and a bit confused. but if your taking the TS file and burning a BD "disk" from it (say, with tsmuxr), then the FPS is wrong...
It needs to be 23.976 for 720 or 1080 resolution, 29.97 wont work...
I did encode and burn a BD with 29.97, and it played, but it was full of jitter.
Again, Im probably looking like an idiot with this reply.
Andrwe -
Nah, the FPS is right. I've burned countless projects without issue from identical sources. If that were true, not only would Tmpgenc not bring the file in as "smart render," but it would be a problem consistent from start to finish. I think I somewhat understand what you are getting at--same with what LMotlow was asking me--that the FPS could be wrong if the source was film versus TV. But i don't think that is the issue, as plenty of shows were fine.
The problem here is characteristic of dropped or corrupt video frames/data. For some reason, other authoring programs are either able to fill them in or power through them. Tmpgenc is not, and I'm not sure if that is a positive or negative about the program; depends how you look at it.
I've tried various stream repair options but they're either over my head or not detecting any problems, so I'm at a loss. Really trying to avoid full re-encodes here as it will not only take hours upon hours, but degrade the quality.
And I'm not looking to use another authoring program, either, as I haven't found anything that does enough of what I want it to do. TMPGenc has the right blend of freedom and ease of use. You can't do EVERYTHING, but you can do enough. -
If your test with multiavchd didn't stutter, and it only authored (not re-encoded), then it suggests the problem is tmgpenc's muxer
You can also test tsmuxer. That doesn't have the ability to re-encode. If that plays smoothly, that's more evidence that supports the assertion that the problem is on tmpgenc's end. If that's the case, you should provide samples and contact them for support so they can fix the issue -
Thanks, that all makes sense. Perhaps it is tmpgenc. I just didn't understand why some were working and some weren't, thus i figured it was a problem specific to the individual files. But your deductions point towards tmpgenc's muxer is logical, so I'll give tsmuxer a shot and contact support.
Thanks! -
I don't know about any of these conclusions. It looks to me that the problem is the old one of BKAC ("Between Keyboard And Chair"). MultiAVCHD is producing a TS file and then you're feeding that .TS into TVAW? Why? TS is for straight HDD/storage playback without menus or other features. If you want to author something, it has to be in a different container, not in the packet configuration for straight .TS. That's probably why TVAW is going into "smart rendering" mode and re-encoding your video. Authoring isn't encoding. Unless, of course, your input is con-compliant encoding or n ot structure for authored BD/AVCHD. Your sample appears to be a 4:3 image set up for 16:9 display, which is what 1440x1080 was designed for. I asked about telecine because a 2-hour-plus 4:3 frame aspect video would sound like a movie to me, and that would be telecine material that should play in 1440x1080 as 23.97 progressive, not interlaced 29.97. But, then your 1440x1080 vid might not be a movie. What are the contents? My main question is, why is an authoring program being used to re-encode your video?
Why? Because I wanted to see if another BD authoring program would work through the kinks and get it ready for TMPGEnc. Thought I was pretty clear with that... When you have limited knowledge you try things to see what works. I also wanted to how other programs might handle dropped frames or other issues. But that doesn't mean the whole problem was caused by me.
It does not have to be in a different container, TMPGenc accepts TS files just fine. That is the container the files are in and I'm authoring BDs with them. It has worked fine plenty of other times. Multiavchd didn't output a TS file, it output an M2TS within a BD structure, which can import into TMPGEnc just fine. It was just for testing.
Tmpgenc is not re-encoding my video... Smart render = does not need full re-encode. It will say that whether it makes minor changes or zero changes. It will show as "FR" (full render) if it has to re-encode. Audio may be re-encoded (AAC to AC3) in 'smart render,' but the video is lossless. If the video content was non-compliant it would show full render. If you're not familiar with the program I'm unsure why you are commenting in the first place. I'm using the term 'smart render' as that is what the program is displaying when the video is imported. It's either one or the other. Doesn't mean it is re-encoding the video. -
I don't know about the first part of your reply, but I've used every version of TMPGenc's encoding and authoring programs since 2002. The reason I commented is that I've never had the problem you describe using that software for a dozen years on thousands of videos (literally), nor have I ever hard of anyone else having that problem with their TMPGenc authoring apps.
Take it or leave it, but I see no reason why you need the smart rendering feature in the first place except for minor cut and join work. I can only surmise that you might have some parts of the video that are maybe interlaced, others that are telecined, or whatever. In that case I take different video formats or frame rates and enter them as separate clips or tracks. Otherwise, you're right: I have no idea why you're having that problem, but I suspect that it shouldn't be happening.- My sister Ann's brother -
I don't "need" it as the files are compliant, but you seem to be insinuating that I am voluntarily selecting to use it. As far as I was aware, it's the default state for importing compliant files. Are you suggesting it's possible to turn off the 'smart rendering' feature?
I mean if that's the case I will, but I wasn't aware it was a 'feature' you could turn off.
It is all one consistent video source/format...Last edited by LIBERT4D; 19th Oct 2014 at 21:24.
I always thought authored BluRay was encoded as m2ts, authored AVCHD encoded as m2t. You like .ts, use it. I wouldn't think of interfering in any way. Have a long and trouble free life.
That is correct, and I never claimed otherwise...
But why would I convert the source file to M2TS when TMPGEnc will handle that in the output process? You seemed to be suggesting that TS files weren't compatible. It's not the issue.
Like I said, I have used other apps to output BD projects using the same footage, and that footage was all fine and stutter-free. But when I fed that result into TMPGEnc--remember, they're M2TS files within a BD folder structure--the stutters were there.
Still curious to see what you thought about the smart rendering thing as I have seen no function to turn off the feature.
