I have a media player that can play progressive scan HD MPEG-4s directly from SDCARDs. It can also take a ripped standard definition DVD and play it when I copy the folder structure to the SDCARD. I want to create my own HD DVD file structure from these files. What happens when you try to author a DVD format that has HD files? Assuming my portable media player can handle it, can I edit my MPEG-4s, then publish them to a DVD format so I have menu selection, etc. The HD/Blu-Ray formatting is new to me so I am not sure what is involved. In an ideal world I could just edit some MPEG-4s together, losslessly save them back out as one MPEG-4, then in a DVD authoring program create the menu structure and wrap the MPEG-4s into VOB files also without degrading them much or at all. If the media player just looks at the BUF and IFO files and they point to a file of any resolution it can handle like HD VOB files, it should play. Thanks for all your help.
Nope, you wont find any dvd authoring applications that accepts hd mpeg4 files without reconverting them.
But the old mkv2vob could remux mkv to a vob....but I'm not sure what you can do with it if you want menus.
Have you tried a blu-ray/avchd on your media player? -
What do the re-author use for mimimum conversion loss? The media player is a Micca Speck. It can take a USB device (stick, hard drive) or an SDCARD. I was just trying to figure out how to take such hiqh quality files and put them through the minimal conversion to get a high quality output. I have taken them and made a regular DVD, but wasn't sure how to make the equivalent of blu-ray quality output. Obviously people are authoring blu-rays. I just want to generate the equivalent of a blu-ray to a file structure on my computer and copy it to the media player and see if it can play it like it plays a DVD or my original MPEG-4 files.
If you want to make a DVD playable on any DVD player, much more than authoring is involved. You have to do a full-scale reencode. And since DVD is standard-def only, you'll lose the high-def quality. Try AvsToDVD to see if you're satisfied with the results.
Ad if your files are already Blu-Ray compliant and just need authoring, then try multiAVCHD.
