Only option I found was WMVTIMES.exe from ffchandler, which I would like avoid using since it crashes for me whenever I want to specify a separate output path:
works,Code:WMVTimes.exe "Path to input file"
like the usage:Code:WMVTimes.exe "Path to input file" "path to output file"
suggests, doesn't. (Sadly there is also no source code available and ffchandler seems to be mia for a few years now.)Usage is: WMVTIMES inputfile[.asf][.wmv] [outputfile[.txt]]
Cu Selur
Ps.: ideally a solution which natively works on Linux and Windows would be preferable, but a Windows only version is okay too.
Works correctly over here
Example:
As a workaround, you could remux to Matroska (with ffmpeg, or via DirectShow), and then extract the timecodes with MKVtoolnixCode:wmvtimes 666video.wmv F:\666times.txt
Also, how about asking Lord Mulder to reinvent the wheel?
FWIW, he already knows how to deal with the WMA timestamps
doesn't work for me.Code:
"G:\Hybrid\WMVTIMES.exe" "C:\Users\Selur\Desktop\file2.wmv" "H:\Temp\timeCode.txt"
-> does it work for you if the output name isn't also the input name (with a .txt extension)?
I would prefer to not have to copy the original file, otherwise I could copy the file first into my temp folder and use WMVTIMES without specifying the output.As a workaround, you could remux to Matroska (with ffmpeg,users currently on my ignore list: deadrats, Stears555, marcorocchini -
Found another workaround by calling ffprobe with -show_packets, and grabbing the video packets pts values. (when writing code, using av_frame_get_best_effort_timestamp() would be probably the call to use)
