I have multiple MKV video files. I would like to view and edit properties like frame width, frame height, frame rate, etc. in a tabulated format. Something like Windows Explorer where you can see these things in a nicely arranged format.
Is there an application which does the job in addition to editing them... something similar to TagScanner which does the job for MP3 what i need in an MKV file
There's the mmg header editor in MKVToolnix but it's not pretty and can only be considered functional at best.
If you need to edit MKVs en masse I find it easier to write batch scripts that call MKVPropEdit to change the values.
If you need to need to set unique values to each file individually things get complicated. Hopefully the new MMG will have a much better header editor.
