  1. x264vfw always compresses at 24 bit color depth. There is a choise "keep input color space". But what about color depth? how to keep it at source bit depth? decrease or increase? or what is the command for that? and also i tried on MeGui's x264 but it always keeps at 12 bit. So important question is: how to compress video at source bit depth in x264vfw?
  2. Originally Posted by chazz spacey View Post
    x264vfw is only compiled with 8bit support. So there is no choice for source bit depth. Note 8bit means 8 bit per channel component. ie. 8bits for each of Y, U, V , or 8+8+8=24
    megui uses x264 which can only be compiled with 8 or 10 bit at compile time. Not 12. (8 and 10 are the only options for x264)
    The "12" is a different style of notation indicating 8bit, subsampled 4:2:0, but really still means 8bits per channel . (Since U, V are 1/2 in each dimension, it's 1/4 of 8, or 2. So 8+2+2=12. By this logic, 8bit 4:4:4 would be 24)
  3. 8 and 10 are the only options for x264
    iirc there should also be a 9bit variant, unless they removed it, but my guess is (aside from me) nobody really cared about the 9bit version
