  1. Codecs: AAC, Sorenson Video 3
    Encoding Software: Sorenson Squeeze 5.0
    I've tried playing the video in QuickTime 10.1 and QuickTime 7. I've also tried VLC.
    I am using: Mac OS X Lion
    Please Help. Thanks
    Sep 2012
    Australia
    -void-
    Does the source have video? What codec is the source?
    Originally Posted by wikipedia
    Sorenson Video 3
    This incompatible version of Sorenson Video uses SVQ3 as its FourCC.
    This version was released with QuickTime 5.0.2 on July 1, 2001. It was available exclusively for QuickTime. Apple QuickTime later focused on other compression formats and moved Sorenson Video 3 to a separate group called "legacy encoders". According to an anonymous developer of FFmpeg, reverse engineering of the SVQ3 codec (Sorenson Video 3) revealed it as a tweaked version of H.264. The same developer added support for this codec to FFmpeg. FFmpeg supports decoding of "Sorenson Vector Quantizer 3" (fourcc SVQ3) and Sorenson Vector Quantizer 1 (fourcc SVQ1) starting with version 0.4.7, released in 2003.
    Sorenson Video 3 comes with Sorenson Squeeze.[14]
  3. Member Cornucopia's Avatar
    Let's make sure we're on the same page: what does MediaInfo say it has?
    When you say no video, do you mean it just shows up as an audio track timeline? or is it all BLACK? or all WHITE? or does it freeze or what?
    Do you have the Sorenson v3 codec component installed? (maybe yours wasn't a full install or was a corrupted install - it should be installed by default, even with minimal/core installs)
  4. Hey ndjamena,
    I really don't know much about video. I gave you all the information that I know. The .mov file should have video. Thanks for doing the lookup, but I'm not sure what it's suppose to mean.
    Sep 2012
    Australia
    So it's not actually your file then. And you know nothing about it.
    Listen to Scott then, I can't add anything to that.
  6. When I say no video I mean it is all black.
    Mediainfo output:
    General
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 593 MiB
    Duration : 58mn 42s
    Overall bit rate : 1 412 Kbps
    Encoded date : UTC 2010-03-25 00:06:36
    Tagged date : UTC 2010-03-25 00:08:48
    Writing library : Apple QuickTime
    com.apple.quicktime.software : Sorenson Squeeze 5.0
    Video
    Format : Sorenson 3
    Codec ID : SVQ3
    Codec ID/Info : Sorenson Media Video 3 (Apple QuickTime 5)
    Duration : 58mn 42s
    Bit rate : 1 344 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Bits/(Pixel*Frame) : 0.146
    Stream size : 565 MiB (95%)
    Language : English
    Encoded date : UTC 2010-03-24 18:36:30
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 58mn 42s
    Source duration : 58mn 42s
    Bit rate mode : Constant
    Bit rate : 64.0 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 26.9 MiB (5%)
    Source stream size : 26.9 MiB (5%)
    Language : English
  7. Member Cornucopia's Avatar
    "ALL BLACK" does NOT mean no video. It means either no (correct) decoder, or the file is corrupted. Or the file is one of an all-black scene (lens cap still on, etc).
    Only way to truly tell would be to post a short segment of it (10-15 sec), and then we could evaluate with other tools/devices. This (creating a segment) can be done quite easily, without re-encoding, using QT Pro.
  8. I'll try to get a video up shortly
