I'm thinking about buying one so I have some questions and ask for advice.
Firstly, is the recorded video in standalone mode easily editable? As in, will it direct stream copy from programs like VideoReDo and whatnot? I know I ran into major problems trying to cut and remux some HD PVR Rocket captures because it didn't seem to recognize the codec.
Also, does it record well enough? As far as bitrate and h264 profile? I don't want to bother if it's, like, 3.1 baseline.
Those are the main issues I had with the PVR Rocket and if this is better, I'll definitely go with it. If it's more of the same, PVR Rocket is fine with me.
Results 1 to 10 of 10
Does the LGP lite record with the same 4.1 profile as the LGP? Thanks!
For the OP, the C985 usually does not get good reviews on encoding quality.
The GameCapture HD II won't connect to a computer, but will probably have superior recording profiles like High L4.1
According to this review, the elgato hd box might support baseline, medium and high profiles
http://www.ezvid.com/elgato-game-hd-review
With the newest Elgato box, you can't tell the difference in picture quality between the raw capture and the elgate when you look at the samples (the video is in the review):
http://www.eurogamer.net/articles/digitalfoundry-2014-elgato-game-capture-hd60-reviewLast edited by ezcapper; 12th Oct 2014 at 22:34.
Thanks Cauptain. Sorry to bother you again, but can you upload a 2 or 3 second black screen so we can analyze the file and see if it is recorded in high profile. I wonder if it is baseline L4.1, thanks!
One more question.
Does it work with MicroSD adapters or does it have to be a full size SD card to work? -
No problem mate. Get here: 720p@60_6seconds_File
C985 record my desktop son.
I had both devices. If you ever going to use PC free mode. Be warned captures tend to skip about 3 to 6 frames every 15 minutes. When it creates the new ts file. System uses fat 32 instead of ntfs unlike the rocket. You will have to join all files together.
If your going attach the device to a PC you will be fine. I personally prefer the rocket over LPG.
