Page 7 of 9
FirstFirst ... 5 6 7 8 9 LastLast
Results 181 to 210 of 251
  1. If anyone could help, I'm trying to download this video:
    https://player.bfi.org.uk/film/watch-london-1994/
    I capture the f4m link via network tab in chrome inspector:
    https://secure-cf-c.ooyala.com/hiNXAwdTq45J2QpzyvBDa2KYn-XaWPAW/hiNXAwdTq45J2QpzyvBDa2KYn-XaWPAW_1.f4m
    but when I do:
    livestreamer "hds://https://secure-cf-c.ooyala.com/hiNXAwdTq45J2QpzyvBDa2KYn-XaWPAW/hiNXAwdTq45J2QpzyvBDa2KYn-XaWPAW_1.f4m" best -o video1.flv
    I get this:
    [cli][info] Available streams: 1200k, 1800k, 2400k, 300k (worst), 4400k (best), 600k
    [cli][info] Opening stream: 4400k (hds)
    [stream.hds][error] Error reading fragment 1-1: Tag has filter flag set, probably encrypted
    [stream.hds][error] Error reading fragment 1-2: Tag has filter flag set, probably encrypted
    [download][video1.flv] Written 842.0 bytes (1s @ 622.5 bytes/s)                 [stream.hds][error] Error reading fragment 1-3: Tag has filter flag set, probably encrypted
    ^CInterrupted! Closing currently open stream...
    any help would be greatly appreciated, if you could explain a proper process as there are more I wish to download from this site whilst I have trial
  2. Hello! I'm new to the forum so I hope this is the right place to ask this questions (I tried the search box and it looks like it hasn't been asked yet).
    Can anyone help me download videos from CBS Press Express? They use the Ooyala player.
    I understand I can use ffmpeg (I have it installed, on Windows 10) but I'm a newbie and I don't know how to make it work. Hope someone can help me, I thank you in advance
  3. Anonymous84347344
    Guest
    I have tried it with a preview video:
    https://www.cbspressexpress.com/cbs-entertainment/video/?watch=7esv6cjf6q
    LIVESTREAMER:
    livestreamer "hds://https://secure-cf-c.ooyala.com/U0ZTU1MjE6MG0aSLALuZ5UJhro1hAT89/U0ZTU1MjE6MG0aSLALuZ5UJhro1hAT89_1.f4m" best -o 01.flv
    [cli][info] Found matching plugin stream for URL hds://https://secure-cf-c.ooyala.com/U0ZTU1MjE6MG0aSLALuZ5UJhro1hAT89/U0ZTU1MjE6MG0aSLALuZ5UJhro1hAT89_1.f4m
    [cli][info] Available streams: 150k (worst), 300k, 600k, 1200k, 2400k, 4400k (best)
    YOUTUBE-DL:
    youtube-dl "https://secure-cf-c.ooyala.com/U0ZTU1MjE6MG0aSLALuZ5UJhro1hAT89/U0ZTU1MjE6MG0aSLALuZ5UJhro1hAT89_1.f4m" -o 01.flv
    [generic] U0ZTU1MjE6MG0aSLALuZ5UJhro1hAT89_1: Requesting header
    WARNING: Falling back on generic information extractor.
    [generic] U0ZTU1MjE6MG0aSLALuZ5UJhro1hAT89_1: Downloading webpage
    [generic] U0ZTU1MjE6MG0aSLALuZ5UJhro1hAT89_1: Extracting information
    [f4m] Downloading f4m manifest
    [f4m] Total fragments: 8
    [download] Destination: 01.flv
    Apr 2016
    Tokyo
    Hello my friends, I am new to this community, in fact this is my first post. I have been trying to download one of these videos all night, if someone could help me, that would be so nice.
    The original URL is: http://www.stockvoice.jp/modules/weblog3/details.php?blog_id=18
    The first fragment of the link is http://apac-prod-1.live-delivery.ooyala.com/out/u/549_3_m1461070779Seg14295-Frag57178 (discovered this with "Flash Video Downloader")
    Then I also found this link with URLSnooper2 http://player.ooyala.com/static/cacheable/d56ecd47e49418a3b13196e6192cca26/player_v2.s...3b6e47ff787a9/[[DYNAMIC]] .... but that didn't do anything.
    After that, I am lost, I have used IDM, but it doesn't pickup the "WMZ(19 APR 2016)" strangely enough, it picks up other videos from other days... I tried realplayer, whole bunch of other downloaders, but to tell you the truth, I am sitting here with a broken arm and if someone could push me in the correct direction, that would be so great.
    I even tried a more complicated method someone posted to youtube using a program called Wireshark and rtmpdump.
    A pre-thanks for the link and a generic push in the correct direction, I assume I will use livestreamer to download but I need the link.
    Thanks man,
    -Joe.
  5. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Here's how I downloaded it using just the link above.
    1. The fragment is 10s long, so the number of fragments for the 1-hour video is about 360 (6 fragments per minute).
    2. The corresponding link for batch downloading with DownThemAll FF plugin:
    http://apac-prod-1.live-delivery.ooyala.com/out/u/549_3_m1461070779Seg14295-Frag[57178:57538]
    3. Renaming of actually downloaded 357 fragments for getting file names Frag1 to Frag357 ( e.g. using Total Commander)
    4. Joining with AdobeHDS Downloader (I use standalone version with embedded php), file size is 566 MB (1280x720, 30fps)
    Apr 2016
    Tokyo
    Alex_ander, you're the man.. man.... wow... took my simple brain some time to do it for the first time, but once it downloaded .. I knew i got it. How did you figure out how the portion in the brackets [57178:57538] ? Just guess?
    Anyways you are friekin' awesome man, you really, really helped me out, thank you.
    Best regards,
    -Joe.
  7. Hi kilihari ,
    1) Given with this answer a file "ZZZ_tentative.txt" to be openned with 'notepad' .
    2) You'll have to modify , with your settings , for :
    _ "E:\php\php.exe"
    _ "E:\php\AdobeHDS.php"
    3) rename the file as "ZZZ_tentative.bat" , to be put in the folder containing 'livestreamer.exe'
    4) launch the batch file . Below what do the batch :
    _ a) catching frags from 57178 to 57534
    _ b) creating a file Seg14295-Frag.flv
    _ c) deleting all files .f4f
    Cheers .
    JE SUIS CHARLIE !!!
    Apr 2016
    Malaysia
    Hello there i need guide to download video from this site :
    original URL : http://www.tonton.com.my/tvShow?titleId=5710a4b22115732c94004246
    URLSNOOPER2: http://player.ooyala.com/static/cacheable/d56ecd47e49418a3b13196e6192cca26/player_v2.s...306bdaff0dce2/[[DYNAMIC]]/5
    http://cdn.http.videos.tonton.com.my/BnaDY0MzE6e2d7JcqtnKxnnRhOFtoJ_a/Zc_6UJuTjDFW5llD...1280Seg1-Frag1 (discovered this with "Flash Video Downloader")
    i cant download this video, been trying all night..
    I hope someone can guide me to download this video.
    still newbie
    Thanks man,
    neverisk
  9. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    This is an encrypted version of F4F stream. Updated versions of Adobe HDS Downloader (since October 2015) might work with it (I haven't tried it):
    https://github.com/K-S-V/Scripts/blob/master/AdobeHDS.php
    (February 2016)
    May 2016
    Maryland
    I am attempting to download the flash video stream on this page:
    http://www3.nhk.or.jp/nhkworld/en/vod/jtripplan/20160418.html
    I attempted to use the HDS Link Detector FireFox Add-on, but I get no command line to execute. Is another tool required? Can anyone help?
    Dave
  11. Hi dhdurgee ,
    My tries :
    php AdobeHDS.php --manifest "http://ak.c.ooyala.com/xkY2V4MjE63Rup2R7nCq7_W6F09QNZ1Z/xkY2V4MjE63Rup2R7nCq7_W6F09QNZ1Z_1.f4m" --delete --outfile J-Trip_plan.flv
    KSV Adobe HDS Downloader
    Processing manifest info....
    Quality Selection:
     Available: 1116 536 256
     Selected : 1116
    Fragments Total: 169, First: 1, Start: 1, Parallel: 8
    Downloading 14/169 fragments
    You'll get J-Trip_plan.flv
    or
    Use the command below:
    livestreamer "hds://http://ak.c.ooyala.com/xkY2V4MjE63Rup2R7nCq7_W6F09QNZ1Z/xkY2V4MjE63Rup2R7nCq7_W6F09QNZ1Z_1.f4m" best -o J-Trip_plan.mp4
    [cli][info] Found matching plugin stream for URL hds://http://ak.c.ooyala.com/xkY2V4MjE63Rup2R7nCq7_W6F09QNZ1Z/xkY2V4MjE63Rup2R7nCq7_W6F09QNZ1Z_1.f4m
    [cli][info] Available streams: 1116k (best), 256k (worst), 536k
    [cli][info] Opening stream: 1116k (hds)
    [download][J-Trip_plan.mp4] Written 19.2 MB (36s @ 576.8 KB/s)
    You'll get J-Trip_plan.mp4
    Cheers .
    JE SUIS CHARLIE !!!
    May 2016
    Maryland
    Originally Posted by aazerty View Post
    Hi dhdurgee ,
    My tries :
    Quality Selection:
     Selected : 1116
    Cheers .
    Thank you for your speedy response. As I had already downloaded AdobeHDS.php I attempted to use it. Initially I got:
    dhdurgee@DHD-Z560 ~/Videos $ php AdobeHDS.php --manifest "http://ak.c.ooyala.com/xkY2V4MjE63Rup2R7nCq7_W6F09QNZ1Z/xkY2V4MjE63Rup2R7nCq7_W6F09QNZ1Z_1.f4m" --delete --outfile J-Trip_plan.flv
    You have to install and enable the following extension(s) to continue: 'curl', 'mcrypt'
    So I went back to the synaptic package manager and added the curl and mcrypt support for php5. Unfortunately, I still get:
    You have to install and enable the following extension(s) to continue: 'mcrypt'
    So for some reason the mcrypt extension is not being recognized. This appears to be a very early error, as I see:
    Any suggestions? I am running Linux Mint x64 17.2 here.
    Dave
    PS: I thought to run php --modules and find that curl is there but mcrypt is not.
    PPS: I decided to download and try livestreamer. It appears to have worked.
    Apr 2016
    London
    Can anyone help me with this video?
    http://www.scoopla.com/stars/blog/2016/5/we-found-out-whether-or-not-michael-fassbende...-fass-bend-it/
    I tried using livestreamer but was given the (403 Client Error: Forbidden) message.
  14. Anonymous84347344
    Guest
    LIVESTREAMER:
    livestreamer "hds://ak.c.ooyala.com/c5MGtrMzE60_zO78eb7nGNwpFL21vXU6/c5MGtrMzE60_zO78eb7nGNwpFL21vXU6_1.f4m" best -o 01.flv
    [cli][info] Found matching plugin stream for URL hds://ak.c.ooyala.com/c5MGtrMzE60_zO78eb7nGNwpFL21vXU6/c5MGtrMzE60_zO78eb7nGNwpFL21vXU6_1.f4m
    [cli][info] Available streams: 500k (worst), 800k, 1200k, 1600k, 2500k (best)
    [cli][info] Opening stream: 2500k (hds)
    MP4:
    http://ak.c.ooyala.com/c5MGtrMzE60_zO78eb7nGNwpFL21vXU6/DOcJ-FxaFrRg4gtDEwOjEzYzowazumG4
    YOUTUBE-DL:
    youtube-dl -F "http://player.ooyala.com/player.swf?embedCode=c5MGtrMzE60_zO78eb7nGNwpFL21vXU6&version=2"
    [Ooyala] c5MGtrMzE60_zO78eb7nGNwpFL21vXU6: Downloading JSON metadata
    [Ooyala] c5MGtrMzE60_zO78eb7nGNwpFL21vXU6: Downloading mp4 JSON
    [Ooyala] c5MGtrMzE60_zO78eb7nGNwpFL21vXU6: Downloading m3u8 JSON
    [Ooyala] c5MGtrMzE60_zO78eb7nGNwpFL21vXU6: Downloading m3u8 information
    [Ooyala] c5MGtrMzE60_zO78eb7nGNwpFL21vXU6: Downloading hds JSON
    [Ooyala] c5MGtrMzE60_zO78eb7nGNwpFL21vXU6: Downloading f4m manifest
    [Ooyala] c5MGtrMzE60_zO78eb7nGNwpFL21vXU6: Downloading rtmp JSON
    [info] Available formats for c5MGtrMzE60_zO78eb7nGNwpFL21vXU6:
    format code  extension  resolution note
    hls-meta     mp4        multiple   Quality selection URL
    hls-32       mp4        unknown      32k , mp4a.40.2, mp4a.40.5
    rtmp-0       rtmp       320x180     232k , h264@ 200k, 25.0fps, audio@ 32k
    mp4-0        mp4        320x180     232k , h264@ 200k, 25.0fps, audio@ 32k
    hls-340      mp4        320x180     340k
    hds-500      flv        unknown     500k
    rtmp-1       rtmp       640x360     596k , h264@ 500k, 25.0fps, audio@ 96k
    mp4-1        mp4        640x360     596k , h264@ 500k, 25.0fps, audio@ 96k
    hls-676      mp4        640x360     676k
    hds-800      flv        unknown     800k
    rtmp-2       rtmp       640x360     896k , h264@ 800k, 25.0fps, audio@ 96k
    mp4-2        mp4        640x360     896k , h264@ 800k, 25.0fps, audio@ 96k
    hls-997      mp4        640x360     997k
    hds-1200     flv        unknown    1200k
    rtmp-3       rtmp       640x360    1296k , h264@1200k, 25.0fps, audio@ 96k
    mp4-3        mp4        640x360    1296k , h264@1200k, 25.0fps, audio@ 96k
    hls-1408     mp4        640x360    1408k
    hds-1600     flv        unknown    1600k
    hds-2500     flv        unknown    2500k  (best)
    Apr 2016
    London
    Thanks, nullacht
  16. Hello everyone.
    I need to download the video on this article:
    http://elcomercio.pe/lima/ciudad/sjl-marca-murio-baleado-al-intentar-asaltar-empresari...oticia-1904874
    May somebody help me out?
    Thanks!.
  17. Anonymous53584
    Guest
    Can someone help me get a download command for this one
    http://www.2dayfm.com.au/shows/hit30/videos/the-voice-coach-ronan-keating/#.V1mAbdUKErE.twitter
    RTMPDump or ffmpeg operhaps? Thank you.
  18. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    (livestreamer)
    livestreamer "hds://http://ak.c.ooyala.com/phaGkxNDE685yMxEj1X5ZHLXHvnkDxLm/phaGkxNDE685yMxEj1X5ZHLXHvnkDxLm_1.f4m" best -o "video.flv"
  19. Can someone help me download this video http://www.hamishandandy.com/2016/best-friends-glamour-photoshoot/
    I have tried fiddler to see what I can pass to livestreamer but can't figure it out.
  20. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    livestreamer "hds://http://ak.c.ooyala.com/ZrNjE1NDE6jXyJrpUlOnemdEEFc_CaLJ/ZrNjE1NDE6jXyJrpUlOnemdEEFc_CaLJ_1.f4m" best -o "video.flv"
    P.S. The file: http://sendfile.su/1242711
  21. Originally Posted by Alex_ander View Post
    Thanks Alex_ander
  22. Anonymous53584
    Guest
    Alex_ander - Awesome. Thank you so much for your help. I'm super curious to learn how to detect the stream's actual URL? Can I find it in Firebug or do I need any other tools? Firebug shows me http URL's to the segments (I think) but I can't figure out the link to the full stream.
    I have another video I'd love to download - http://www.929.com.au/shows/rove-and-sam/videos/ronan-keating-and-delta-goodrem-play-sweet-and-sour/
  23. Anonymous84347344
    Guest
    livestreamer "hds://ak.c.ooyala.com/03MHI0NDE6sUE8oG0P00iBg7iVbXl0u8/03MHI0NDE6sUE8oG0P00iBg7iVbXl0u8_1.f4m" best -o 01.flv
    [cli][info] Found matching plugin stream for URL hds://ak.c.ooyala.com/03MHI0NDE6sUE8oG0P00iBg7iVbXl0u8/03MHI0NDE6sUE8oG0P00iBg7iVbXl0u8_1.f4m
    youtube-dl -F "http://www.929.com.au/shows/rove-and-sam/videos/ronan-keating-and-delta-goodrem-play-sweet-and-sour/"
    [generic] ronan-keating-and-delta-goodrem-play-sweet-and-sour: Requesting header
    [generic] ronan-keating-and-delta-goodrem-play-sweet-and-sour: Downloading webpage
    [generic] ronan-keating-and-delta-goodrem-play-sweet-and-sour: Extracting information
    [Ooyala] 03MHI0NDE6sUE8oG0P00iBg7iVbXl0u8: Downloading JSON metadata
    [Ooyala] 03MHI0NDE6sUE8oG0P00iBg7iVbXl0u8: Downloading f4m manifest
    [Ooyala] 03MHI0NDE6sUE8oG0P00iBg7iVbXl0u8: Downloading m3u8 information
    [info] Available formats for 03MHI0NDE6sUE8oG0P00iBg7iVbXl0u8:
    hls-318      mp4        320x180     318k
    hls-697      mp4        640x360     697k
    hls-1023     mp4        640x360    1023k
    hls-1456     mp4        640x360    1456k
    youtube-dl "http://player.ooyala.com/nuplayer?adSetCode=3884d5e47eb04bad8b6d72f63d446af0&embedCode=03MHI0NDE6sUE8oG0P00iBg7iVbXl0u8&playerBrandingId=MmUwYmY4MmIyNmE0OWI0MmQwNGUxMDdi"
    [f4m] Total fragments: 18
    [download] Destination: 'The Voice' Judges - Ronan & Delta Play Sweet & Sour-03MHI0NDE6sUE8oG0P00iBg7iVbXl0u8.flv
  24. Thank you all for the tips!
  25. Hello all,
    Can someone who is good with figuring out the links for ooyala files please private message me ASAP? I have a time-sensitive video, and I'm lost in some of these instructions. Thanks so much!
  26. DOWNLOAD OOYALA VIDEO WITH ANDROID
    Go to /data/data/com.android.chrome/cache/Media Cache
    Sort by date and time.
    _s is file
    _0 is decrypt key
    open “_0” as .txt and go to direct link
    example
    http://cf.c.ooyala.com/long_string-OF/C0DE-UPtoTHEquestionMark?
    Now save page and you have your media file, or hold your thumb on the video and SAVE VIDEO
    You should be able to open the _0 file to get the extension and apply the extension to the _s file, but this does not always work.
  27. Hey guys, I've tried several things to get this video but failed, I don't really know what I'm doing to be honest so if someone can help with this that'd be awesome.
    http://eversport.tv/fight-sports/rizin/2016/9/25/cygames-presents-world-grand-prix-2016
  28. Originally Posted by Atman1 View Post
    hi
    http://cf.c.ooyala.com/xobmwzNjE6WQ6JiRnOW1Ll-sMezm12B2/DOcJ-FxaFrRg4gtDEwOjIwbTowODE7WK
  29. Originally Posted by biezom View Post
    hi
    Oh wow, thank you very much! I'm curious how you managed to find that url, do you mind telling me please?
