Page 6 of 9
FirstFirst ... 4 5 6 7 8 ... LastLast
Results 151 to 180 of 251
  1. Member vhelp's Avatar
    Mar 2001
    New York
    solved the "how to download videos from FloTrack" -- from post # 145, #147 and #150
    The video I wanted to download:
    http://www.flotrack.org/video/802970-workout-wednesday-fartlek-with-the-15-iowa-state-women
    All the info *is* in the view_page_source script, analyzed, parsed, and build the final url.
    It did not work in latest youtube-dl v12.13, but it worked well with livestreamer 1.12.2
    If you don't want to spaces then you have to insert '-' into the filename, and it would help to be enclosed in quotes, "".
    livestreamer http://32598.cdx.c.ooyala.com/d3eWxseDqf6BxwlaGBkhh491BQw5KWWZ/d3eWxseDqf6BxwlaGBkhh491BQw5KWWZ_1.f4m best -o "Workout-Wednesday:-Fartlek-with-the-#15-Iowa-State-Women.flv"
    or keep it more simplified and rename it later.
    livestreamer http://32598.cdx.c.ooyala.com/d3eWxseDqf6BxwlaGBkhh491BQw5KWWZ/d3eWxseDqf6BxwlaGBkhh491BQw5KWWZ_1.f4m best -o video.flv
    And here is the livestreamer processed output.
    [cli][info] Found matching plugin stream for URL hds://http://ak.c.ooyala.com/d3eWxseDqf6BxwlaGBkhh491BQw5KWWZ/d3eWxseDqf6BxwlaGBkhh491BQw5KWWZ_1.f4m
    [cli][info] Available streams: 1500k, 2500k (best), 600k (worst)
    [cli][info] Opening stream: 2500k (hds)
    [download][video20151214mon01.flv] Written 2.2 MB (5s @ 429.9 KB/s)
    [download][video20151214mon01.flv] Written 5.1 MB (10s @ 487.0 KB/s)
    [download][video20151214mon01.flv] Written 8.3 MB (16s @ 516.8 KB/s)
    [download][video20151214mon01.flv] Written 11.4 MB (21s @ 539.8 KB/s)
    [download][video20151214mon01.flv] Written 14.2 MB (28s @ 509.8 KB/s)
    [download][video20151214mon01.flv] Written 16.8 MB (35s @ 487.6 KB/s)
    [download][video20151214mon01.flv] Written 19.9 MB (40s @ 503.3 KB/s)
    [download][video20151214mon01.flv] Written 22.6 MB (46s @ 486.8 KB/s)
    [download][video20151214mon01.flv] Written 25.8 MB (55s @ 434.6 KB/s)          [stream.hds][error] Failed to parse fragment 1-11: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [download][video20151214mon01.flv] Written 28.9 MB (1m5s @ 413.4 KB/s)         [stream.hds][error] Failed to parse fragment 1-13: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-14: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-15: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-16: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-17: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-18: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-19: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-20: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-21: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-22: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-23: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [download][video20151214mon01.flv] Written 31.9 MB (1m15s @ 392.0 KB/s)        [stream.hds][error] Failed to parse fragment 1-25: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [download][video20151214mon01.flv] Written 35.0 MB (1m24s @ 358.9 KB/s)        [stream.hds][error] Failed to parse fragment 1-27: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [download][video20151214mon01.flv] Written 38.0 MB (1m32s @ 347.3 KB/s)
    [download][video20151214mon01.flv] Written 41.1 MB (1m36s @ 380.5 KB/s)
    [download][video20151214mon01.flv] Written 44.0 MB (1m41s @ 425.0 KB/s)
    [download][video20151214mon01.flv] Written 47.0 MB (1m47s @ 487.9 KB/s)
    [download][video20151214mon01.flv] Written 50.0 MB (1m53s @ 523.3 KB/s)
    [download][video20151214mon01.flv] Written 53.2 MB (1m58s @ 586.7 KB/s)
    [download][video20151214mon01.flv] Written 56.0 MB (2m5s @ 524.8 KB/s)
    [download][video20151214mon01.flv] Written 59.1 MB (2m14s @ 471.8 KB/s)        [stream.hds][error] Failed to parse fragment 1-36: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-37: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-38: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-39: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-40: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-41: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-42: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-43: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-44: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [stream.hds][error] Failed to parse fragment 1-45: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [download][video20151214mon01.flv] Written 62.2 MB (2m23s @ 431.2 KB/s)        [stream.hds][error] Failed to parse fragment 1-47: Failed to read data: [Errno 10054] An existing connection was forcibly closed by the remote host
    [cli][info] Stream ended
  2. Originally Posted by vhelp View Post
    hi
    direct link
    http://32598.cdx.c.ooyala.com/d3eWxseDqf6BxwlaGBkhh491BQw5KWWZ/DOcJ-FxaFrRg4gtDEwOjI5cDowODE7AZ
  3. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    (that direct link didn't work for me, access denied)
    Here's an example of getting it by mass downloading of fragments (no DRM encryption here), then joining. Download links here can be taken form FF extensions like (flashgot + DownThemAll) or AddBlockPlus. Downloading 48 fragments with DownThemAll (Frag1 in partial file name changed to Frag[1:48] accepted by that Firefox extension):
    http://32598.cdx.c.ooyala.com/d3eWxseDqf6BxwlaGBkhh491BQw5KWWZ/sqq_-2i8oVwubLc-UFMFM6p-4aCdMclycVa7qUy0KZ_jizdDwqrRXBuLhY2UR-nZ/video_2500_1280Seg1-Frag[1:48]
    Joining with AdobeHDS.exe (third party standalone version of the KSV script):
    AdobeHDS --fragments c:\Users\user\path\video_2500_1280Seg1-Frag
    (148MB .flv)
  4. Member vhelp's Avatar
    Mar 2001
    New York
    link: http://32598.cdx.c.ooyala.com/d3eWxseDqf6BxwlaGBkhh491BQw5KWWZ/DOcJ-FxaFrRg4gtDEwOjI5cDowODE7AZ
    The 'access denied' you received might be due to a region problem because the link worked for me. This time, i used youtube-dl.
  5. Member vhelp's Avatar
    Mar 2001
    New York
    I can download *some* videos from the FloTrack website using firefox via the download plug-in's. But sometimes even the same video I just download then become segmented and I can no longer download them. Its very strange, but that's what I have been discovering.
  6. Hello, trying to download video from
    http://www.bizjournals.com/washington/news/2015/08/27/meet-sam-the-robot-laying-bricks...ide-clark.html
    I have download livestreamer and have tried to mimic what other posts had, but is not working.
    Please help
    what i tried:
    livestreamer "hds://http://cf.c.ooyala.com/N3d3U3dzpyqS65SIr1MwiwJYtO36CMPw/N3d3U3dzpyqS65SIr1MwiwJYtO36CMPw _1.f4m" best -o meet-sam-the-robot-laying-bricks-alongside-clark.flv
  7. Originally Posted by z123111 View Post
    Please help
    what i tried:
    hi you have a space between red en blue
    try without this space
    livestreamer "hds://http://cf.c.ooyala.com/N3d3U3dzpyqS65SIr1MwiwJYtO36CMPw/N3d3U3dzpyqS65SIr1MwiwJYtO36CMPw_1.f4m" best -o meet-sam-the-robot-laying-bricks-alongside-clark.flv
  8. Thank you!!!!!!!!!!!!!!!!
  9. Originally Posted by Dee_Bee View Post
    hi
    it seems no direct link exist
    so you can use the hds protocol
    livestreamer "hds://http://ak.c.ooyala.com/U5cjYwdjqJd_ulfWcUP6RfTnyJdcWAAW/U5cjYwdjqJd_ulfWcUP6RfTnyJdcWAAW_1.f4m" best -o video1.flv
    livestreamer "hds://http://ak.c.ooyala.com/w3eTcwdjrFfJIO_GxyL_6W2wiVLo3ptQ/w3eTcwdjrFfJIO_GxyL_6W2wiVLo3ptQ_1.f4m" best -o video2.flv
  10. Grateful thanks for quick response. I have downloaded and installed 'livestreamer' into my laptop running W8.1. Having realised A) I had to paste the command into an elevated command prompt B) Ignored the multiple error closing messages until the script had completed and C) Where the .flv files ended up: I now have the 2 valuable video files I can use in Studio 15.
    You are a star! I wish you well!
    Kind regards - DeeBee
  11. One last one I promise - I need to download the following:
    http://www.bbc.co.uk/news/magazine-27066299
    If you can help with a direct link or script I'll try to get to grips with livestreamer over the Christmas period.
    Kind regards - Dee Bee
  12. can anyone teach me how to download this video...http://www.tonton.com.my/movie?titleId=550bfc3626fcd3595d0041e8 i try use url snooper and adobe hds still cant get.. adobe hds said encrypted manifest..
  13. Hi, I just found your thread when looking for a way to download a video from Ooyala.
    I am trying to download the video from this website: http://fox8.com/2016/01/18/whos-mashed-with-whom-artist-creates-amazing-celebrity-face-mashups
    The links seems to be
    http://cf.c.ooyala.com/F0Mnk5MDE6a9fwdPAQks2FjtthDER8Nv/Qg5k4R_PhKtsf_S8XsdjYMfg-NG22N...ym9YlxUXJ-ngFR
    but the access is denied. It is no geoblocking issue it seems, as I can view the video on the website.
    Is there a way to download it? Otherwise I will try a screen grab. That always works, but is not the best solution.
  14. Originally Posted by skyscraperfan View Post
    HTML Code:
    livestreamer "hds://http://cf.c.ooyala.com/F0Mnk5MDE6a9fwdPAQks2FjtthDER8Nv/F0Mnk5MDE6a9fwdPAQks2FjtthDER8Nv_1.f4m"  best -o video.flv
  15. Originally Posted by goodiesguy View Post
    hi
    livestreamer "hds://http://ak.c.ooyala.com/xsMzE4eTrmtIuuy_JSXWEUN2MPRBDaVB/xsMzE4eTrmtIuuy_JSXWEUN2MPRBDaVB_1.f4m" best -o Liverpool-a-Go-Go.flv
    or
    livestreamer "hlsvariant://http://player.ooyala.com/player/iphone/xsMzE4eTrmtIuuy_JSXWEUN2MPRBDaVB.m3u8" best -o Liverpool-a-Go-Go.ts
  16. hi
    http://cf.c.ooyala.com/1qZXVsMDE6a21wS3oR40IhgaRWczZH9B/DOcJ-FxaFrRg4gtDEwOnI5OjA4MTulQ8
    http://cf.c.ooyala.com/hpOG9rMDE6CNYR_rxbu0cqmo_taxWbf0/DOcJ-FxaFrRg4gtDEwOnI5OjA4MTulQ8
    http://cf.c.ooyala.com/RxdmRrMDE6w-NRyWg_KQ8BeYKyGHajdS/DOcJ-FxaFrRg4gtDEwOnI5OjA4MTulQ8
    Feb 2016
    peru
    Hello everyone I hope I can help me download a novel but can not find the way, I hope someone can give me an idea how to do it, of course thank you very much
    http://canalnuestratele.com/video/mano-limpia-capitulo-01-9727
  18. Member
    Feb 2016
    Malaysia
    Hi, biezom, im totally newbies. i sniff using (Wireshark+LiveStreamer) but nothing work.
    could you pls help me with this link : "http://www.tonton.com.my/movie?titleId=55a36250221573d16300421e"
    -Thank you
  19. Originally Posted by Durian View Post
    -Thank you
    hi
    not easy way see your pm
    Oct 2015
    Brussels
    Hello,
    I have been trying to read through all these tips, but this programming language does not fit me. Could someone help me with this link?
    Or tell me clearly how i should do it?
    http://www.demunt.be/nl/mymm/media/2486/H%C3%A4nsel%20und%20Gretel/
    Ty
  21. Anonymous84347344
    Guest
    YOUTUBE-DL:
    youtube-dl -F "http://www.demunt.be/nl/mymm/media/2486/H%C3%A4nsel%20und%20Gretel/"
    [generic] Hänsel und Gretel: Requesting header
    WARNING: Falling back on generic information extractor.
    [generic] Hänsel und Gretel: Downloading webpage
    [generic] Hänsel und Gretel: Extracting information
    [Ooyala] xmamVzMDE64SoMpMSZ2nvKJ1LE52SVpw: Downloading JSON metadata
    [Ooyala] xmamVzMDE64SoMpMSZ2nvKJ1LE52SVpw: Downloading mp4 JSON
    [Ooyala] xmamVzMDE64SoMpMSZ2nvKJ1LE52SVpw: Downloading m3u8 JSON
    [Ooyala] xmamVzMDE64SoMpMSZ2nvKJ1LE52SVpw: Downloading hds JSON
    [Ooyala] xmamVzMDE64SoMpMSZ2nvKJ1LE52SVpw: Downloading rtmp JSON
    [info] Available formats for xmamVzMDE64SoMpMSZ2nvKJ1LE52SVpw:
    format code  extension  resolution note
    rtmp-0       rtmp       576x324     628k , h264@ 500k, 25.0fps, audio@128k
    mp4-0        mp4        576x324     628k , h264@ 500k, 25.0fps, audio@128k
    rtmp-1       rtmp       576x324     928k , h264@ 800k, 25.0fps, audio@128k
    mp4-1        mp4        576x324     928k , h264@ 800k, 25.0fps, audio@128k
    rtmp-2       rtmp       576x324    1392k , h264@1200k, 25.0fps, audio@192k
    mp4-2        mp4        576x324    1392k , h264@1200k, 25.0fps, audio@192k
    rtmp-3       rtmp       1280x720   1692k , h264@1500k, 25.0fps, audio@192k
    mp4-3        mp4        1280x720   1692k , h264@1500k, 25.0fps, audio@192k (best)
    youtube-dl -F "http://player.ooyala.com/player.js?callback=receiveOoyalaEvent&playerId=ooyalaPlayer&width=568&height=426&wmode=opaque&hide=channels,sharing,info,embed,endscreen&embedCode=xmamVzMDE64SoMpMSZ2nvKJ1LE52SVpw"
    MP4:
    http://ak.c.ooyala.com/xmamVzMDE64SoMpMSZ2nvKJ1LE52SVpw/DOcJ-FxaFrRg4gtDEwOjFjZjowODE7Ww
  22. Struggling here also, having installed livestreamer, followed instructions, etc.
    If someone were able to provide a direct link to this one, t’would be greatly appreciated!
    Thanks in advance!
  23. hi,biezom.
    i have met the same problem,when i use livestream to download tonton.com.my f4m.
    the cls report error like this:
    Error reading fragment 1-11:Tag has filter set,probably encrypted.
    i guess the tonton website use DRM to protect video, and cant download use any methods.
    is it true?
    thank you very much.
    -Thank you
    hi
  24. Originally Posted by tltlv View Post
    hi,biezom.
    is it true?
    -Thank you
    hi
    hi
    same see your PM
  25. Member
    Mar 2016
    Tulsa
    Hi everybody - I'm a complete newbie at this all, but I really would love somebody's help.
    Can somebody please download these 3 flotrack videos for me? It would seriously mean the world to me.
    http://old.flotrack.org/video/162918-3000m-Junior-Men-National
    http://old.flotrack.org/video/273950-Capital-Classic-JM-1500m
    http://old.flotrack.org/video/166159-1500m-Men-16-Final-Sunday
    They are from a few years ago when I was a runner and I really would love to keep them on my computer forever, except I am not as tech savvy as y'all.
    Thanks - you guys are the best.
  26. Originally Posted by runnerb View Post
    hi
    direct links
    http://cf.c.ooyala.com/hobnlhODpHm3vaVv-s6tWRfPZZS25ZM5/DOcJ-FxaFrRg4gtDEwOnYyOjBmO80IGG
    http://cf.c.ooyala.com/1id2dyNjpgsVkofmOa0T5voMNDVlk0bV/DOcJ-FxaFrRg4gtDEwOjE0NjowZjsy-U
    http://cf.c.ooyala.com/lyZTFjODp6X1wo7UjF6kiwfPj59Q_gMM/DOcJ-FxaFrRg4gtDEwOjE0YTowZjueqf
  27. Member
    Mar 2016
    Tulsa
    hi
    direct links
    Thank you OMG you are the best. Means a lot.
