Page 2 of 9
Results 31 to 60 of 251
    Jan 2014
    India
    Originally Posted by blimey View Post
    Changing headers to a user agent from a mobile platform like ios or android should work. Did you also disable the flash plugin?
    Another method is to request the url directly from the ooyala authorization server. But it returns it in base64 - although that is easy to decode. I will make a list of foolproof steps.
    can you please help me i tired changing the header and disabling the flash but i still cant get the URL without DRM please help me bro
    Nov 2014
    London
    Need help to download this link
    thanks
  3. I am happy to report that I have made several improvements to the tool. First off I found what has been causing the ooyala errors (Was obscure) and have fixed it.
    Second the service now supports whats I call generics. This means if a site has a video embedded, then it will be smart about it and try and detect the video service and follow the trail. So there will be no need to add domains to be supported anymore. This currently works on Ooyala and YouTube. Others will come soon.
    You do not need to get the player.ooyala.com address either. A working example is http://www.rollingstone.com/music/videos/norwegian-dj-cashmere-cat-goes-spartan-on-wit...miere-20131219.
    Also, @blimey, from what I can see the backend server doesn't do a header check since I was able to access the mobile code in chrome.
    Sorry for the delays in getting this fully working. If you have any issues, just reply, PM me, or use the support tab on the site.
    Peace..
  4. Deceased
    Dec 2007
    See next message...
  5. Originally Posted by blimey View Post
    I'm not sure what you're claming. For your example;
    http://www.rollingstone.com/music/videos/norwegian-dj-cashmere-cat-goes-spartan-on-with-me-premiere-20131219
    With default headers and flash installed/enabled, when the above page is loaded, the flash player will load and fetch the content via rtmp. With default headers but flash disabled, a message asking flash for to be installed will be displayed.
    But with full and complete ipad headers, and flash disabled, the same page will will load a mp4 player and fetch the content via progressive http url from ooyala.
    Of course "the mobile code" can be accessed without header changes. But there is definitely logic in the loading of the page (based on the header/user agent) that determines the platform. There has to be, or else why isn't the flash player served up to mobile devices? Or why isn't the mp4 player served to a desktop browser with flash enabled?
    It has to be either mp4 or rtmp for the content on this page, as there is no hls or hds in this case. And there has to be logic to send one or the other or none at all, but not all (or both).
    I understand now, got confused. My methods are via mobile not using the desktop versions.
  6. Hi pokkiri ,
    Here below my try .
    Copy and paste the text below in a text editor . Save it as "whatyouwant.bat" , in php's directory .
    @echo on
    php AdobeHDS.php --manifest "http://ak.c.ooyala.com/B1NjJ0cTrJCogMhUYMXneJqL2M2YGi8-/B1NjJ0cTrJCogMhUYMXneJqL2M2YGi8-_1.f4m" --delete
    pause
    :fin
    === Process running for the best quality !!!
    KSV Adobe HDS Downloader
    Processing manifest info....
    Quality Selection:
     Available: 3600 2200 1500 900 600 300
     Selected : 3600
    Fragments Total: 870, First: 1, Start: 1, Parallel: 8
    Downloading 9/870 fragments
    If needed an other quality , add :  --quality 1500 <= example
    After waiting a moment I get :
    This stream is encrypted with FlashAccess DRM. Decryption of such streams isn't currently possible with this script.
    Cheers .
  7. Deceased
    Dec 2007
    It is not always the same in every case. What is the website/video?
  8. Hi blimey ,
    Thanks for your informations . It works .
    Cheers .
    Nov 2014
    London
    thanks working
    Nov 2014
    London
    is there any option to cheat ooyala and get a direct source link
  11. Originally Posted by pokkiri View Post
    Use http://www.directvideostreamer.com/
    Nov 2014
    London
    not working bro
  13. Originally Posted by pokkiri View Post
    not working bro
    Please provide the URL so I can look at it then.
  14. Member Emeritus
    May 2014
    Why must I install client side java on my end in order to use your website? There must be some other way you could set it up. I wouldn't be caught half dead using client side java facing some basically unknown website.
  15. Originally Posted by ponens View Post
    1. Its the only way to do it for IP restricted videos
    2. It uses your IP to get the video
    3. It costs $70-$80 to get a code cert to make it "trusted".
    4. Every other technology/platform has too many security restrictions in place to allow the app to work it in. Unless you ran a desktop APP, its the only way to have it work.
    If you think im giving you a virus, don't use it and find another way.
    Thanks!
    Nov 2014
    London
    is it a movie or a trailer, When i open the link IDM is getting me the link of 1:06 mins video in 720p resolution, its downloading fine
  17. Hi pcfreak30 ,
    Instead of writing "http://directvideostreamer.com/" ,
    create a page in the section "https://www.videohelp.com/tools/" .
    Name it what you want , and explain exactly what you can do .
    And FREE or PAY !!!
    Regards .
  18. Originally Posted by aazerty View Post
    Hi pcfreak30 ,
    And FREE or PAY !!!
    Regards .
    Its not a downloadable tool, so I don't think it can go there?
  19. Hi pcfreak30 ,
    What I suggess : each time you give your link , is to add the infos below .
    ABOUT : http://directvideostreamer.com/
    1) Its the only way to do it for IP restricted videos
    2) It uses your IP to get the video . It is not a downloadable tool .
    3) It costs $70-$80 to get a code cert to make it "trusted".
    4) Every other technology/platform has too many security restrictions in place to allow the app to work it in.
       Unless you ran a desktop APP, it is the only way to have it work.
    Note :
    _ for people needing a film , it's better to subscribe directly to the provider .
    _ You say 70$-80$ . Very expensive !!!
    _ Your link is "border-line" (?) .
    Cheers .
  20. Can anyone help me get the vid from
    https://www.groupon.com/deals/bikram-yoga-huntington-beach-2#ooid=tubGNycTo_9Uxg82uESj4i61EYX8nyuf
    I'm trying to use youtube-dl on brew.
    Thanks,
    David
  21. When I try to get"
    it says site not supported.
    Can you help?
  22. Member
    Nov 2014
    London
    ooyala is the player , IDM is been taking direct download . Install internet download manager
  23. Thanks for your reply. I am on a mac so that does not work for me.
  24. Member
    Nov 2014
    London
    it is not DRM protected (I donno about paid version) So use f4m main stream to download
  25. I booted into windows and used IDM. It worked! Thanks pokkiri.
  26. Originally Posted by blimey View Post
    See next message...
    @blimey :
    Can you help me downloading other files please ?
    youtube-dl would not work and I don't get how you find the direct link for the video in Ooyala player...
    Here are my 5 links (2 hours videos for each link) :
    http://eversport.tv/football/conifa-world-football-cup/2014/6/7/wfc-2014-placement-abk...n-occitania-de
    http://eversport.tv/football/conifa-world-football-cup/2014/6/5/wfc-2014-placement-ass...a-de-fotbol-vs
    http://eversport.tv/football/conifa-world-football-cup/2014/6/4/wfc-2014-quarter-arame...vs-association
    http://eversport.tv/football/conifa-world-football-cup/2014/6/3/wfc-2014-group-associa...e-fotbol-vs-fa
    http://eversport.tv/football/conifa-world-football-cup/2014/6/1/wfc-2014-group-abkhazi...-occitania-vod
    modification:
    Just realised blimey has been banned !
    Does anyone know why or have an answer to my questions (except directvideostreamer).
    I'd like to have the m3u8 link to use livestreamer or anyother method
  27. Member
    Nov 2014
    London
    See next message...
    @blimey :
    modification:
    simply IDM is grabbing the link. Install internet download manager
