Results 1 to 9 of 9
  1. Hey Guys I Had Some videos
    I checked Those Media Infos
    Here It is:
    Writing application : Lavf56.3.100
    Writing library : x264 core 122 r2184 5c85e0a
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=16 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=96 / keyint_min=9 / scenecut=0 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=2509 / vbv_bufsize=2509 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
    Whats The Application Used ???
    Whats That : Lavf56.3.100
    Help it To Find
  2. Originally Posted by videobruger View Post
    Encoder: x264
    Yep Whats The Writing Applcition Used???
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I'm going with ffmpeg.
    Mar 2011
    Nova Scotia, Canada
    Tons of GUI encoders ... and not just free ones ... are just a front end for free open source programs, and programs like mediainfo won't generally tell you what the front end is. Just the back end.
  5. Member racer-x's Avatar
    Mar 2003
    No doubt, it's ffmpeg. Here is a recent ffmpeg encode I did:
    Format                         : MPEG-4
    Codec ID                       : isom
    Writing application            : Lavf56.4.101
    Writing library                : x264 core 142 r2479 dd79a61
    Encoding settings              : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=10 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
  6. it's at least libav (could be x264 itself when compiled with the proper extensions)
  7. Originally Posted by racer-x View Post
    Format                         : MPEG-4
    Codec ID                       : isom
    Yep u r right
