Originally Posted by
hstrent51
usually_quiet
hstrent51
I'm done with this one. Any way to edit the thread title to add [Solved]?
Yes. You should see a text box for editing the thread title in a thread that you created when using the "Go Advanced" option to edit one of your posts.
I did that but it doesn't show up in the thread title once I save it. I'm looking at it right now as I type but when I Submit Reply to save the change it is not visible in the Newbie/General discussions forum view.
Maybe it only works when you edit your initial post for the thread, or maybe the thread title is too long once you add "Solved", so the addition was omitted.
I know I added "Solved" to one of my own thread titles in the past, and I'm sure that is how I did it.
