  1. There's an option in the OneClick > "Other" tab to set D2V as the Indexer priority.
    In the Avisynth Profile > Extra Setup tab I can tick "MPEG2 Deblocking". However I checked the script it makes and it uses CPU=4 instead of CPU=6. How can I set it to CPU=6?
  2. Does megui have an option for mpeg deringing? That's the difference between CPU=4 and CPU=6.
  3. Thanks.
    Also in MeGUI I use 4.0 profile for 720p 50fps Blurays for example. As shown in this table: http://forum.doom9.org/showthread.php?t=154533
    Was wondering what profile I should select for SD 480i/576i? They are under 10 Mbps
    What max ref frames and Slices should I use?
    What vbv-maxrate and vbv-bufsize should I set? Thanks
    May 2014
    Memphis TN, US
    I think you've been to the link below earlier. 5 or 6 tables on the page (scroll down). Got this link a while back when it was posted in one of your threads.
    http://forum.doom9.org/showpost.php?p=1399419&postcount=1
    - My sister Ann's brother
  5. I read the tables but I'm still not sure what is OK for SD.
