I am confused with applying transition effect of Vegas pro 13
The program will lengthen the clips itself ,
so the scene during transition is not what I want
I have recorded the screen
Anyone know what's wrong ?
Download link :
https://mega.co.nz/#!ulghTYSJ!sEnRL_yOBxkAX8TAjVZ0phS7zp5AByPKJXjexC6I2Wc
[Solved]
	Have you dragged the event edges to overlap first? Try dragging the events to overlap instead.
	A "Transition" is a blend of the end of the first video to the beginning of the next one. So a transition can only be applied to the overlap area, if you're using a canned transition.
 Push the two ends together, so they overlap, and right click to choose the canned transition. It's as simple as falling off a log.Last edited by budwzr; 7th Oct 2014 at 17:56.
	OK !
 Dragged the event edges to overlap first !
 It works !
 Thanks Smrpix
 Thanks Vkmast
 Thanks Budwzr
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
