Hello all,
My 1212 after years of reliable service has given up the ghost (probably from a recent thunderstorm). It appears to boot up, but the USB is dead (USB device not found). Unfortunately, Hauppauge was no help in resolving the issue (somewhat of a runaround between Tech Support and Sales). Pulled the board out, touched up any cold looking solder joints, but still no joy.
Anyway, I used the 1212 primarily for recording HD shows, etc. off cable (via component/optical). I have it set to PS3/m2ts at 5 Mbps. It's running on a 3 GHz Celeron (single core) CPU with 1 GB RAM, and couldn't be happier. I would like to run a bit higher on the bitrate, but the CPU is the limiting factor.
My question is, do I spend the ~$200 for another 1212 (which I know works) or go with the less expensive (~$150) 1512 HD-PVR 2?
Given the CPU/bitrate limitations I have, has anyone experienced any issues for the 1512?
Also, if anyone has suggestions for alternatives for the 1212/1512, again, taking into account the PC limitations I have, it would be appreciated.
Thanks,
Bill
If you happen to be using Linux (as I suspect you may be on account of the low-spec hardware in your HTPC) there are no Linux drivers for the HD-PVR 2.
ezcapper, please read our rules before posting. No unsolicited advertising.Advertising
You must contact the webmaster and get permission before you attempt to post solicitations or advertising. Anything that appears to be advertising or solicitation will be removed immediately. This does not apply to LEGITIMATE news or user guides.
Moderator redwudzLast edited by redwudz; 8th Oct 2014 at 00:22.
I've had the 1512 for a few weeks now and have used it to capture video from my satellite box as well as my PS4. I've had no issues with it. It's been working great.
