Hi,
I'm new here, but I really hope some experts can help me out.
I have a Sony KDL-50W828B LCD tv. I use a USB harddrive and the MediaPlayer app available in the Sony app store on my tv to play my movies. The movies are either .MKV or .MP4 (1080p). I use .SRT-files (Unicode) for subtitles.
My problem is that all subtitles show up on my tv in a black box. The box is a bit transparant ('opaque'), but still - I don't want that. I just want white letters, black borders, maybe a little shading - just like normal TV-shows. I tried using the .ASS format, but it seems the formatting gets overruled: the subtitles always show up in the same font, in that black box.
Sony support insists this is a problem with my subtitle files, that supposedly contain formatting info, but they don't - they are just .SRT-files with no formatting info whatsoever.
Does anybody recognize this? Does anyone have any suggestions? Things I could try?
The Media Player app does not seem to have any settings I could fiddle with, and I have not been able to find out who actually created that app, so I can't ask for their help either.
Thanks for your ideas!
Vok D
Results 1 to 9 of 9
You could try make image sub/idx/dvd subtitles with something like Txt2VobSub and mux into your mkv....but they wont look as good as srt text subs.
Or try ask/search in a sony app forum if they have found a better solution to adjust font settings in tha player app. -
Well over here, our 'normal tv-showa' subtitles appear in a black box.
Of course dvds etc. are different. -
Usually "subtitles" that appear in a black box are from Closed Caption.
Like from a TV show broadcast.
And I have had TV shows on DVD that did not have actual subtitles but did have closed captions as when I ripped them to convert to Xvid
I would extract the CC's and convert them to SRT subs to include with the Xvids. -
But Vok D has the subs in srt format already. I'm pretty sure the tv player app adds the black bars.
