hi
sadly the registration at the avidemux forums is disabled, i dunno why, i hope you can help me here as im not very familiar with video stuff at all! only a bit.
i have some videos i wanna:
1. convert from avi to mp4 losless if possible?
- i chose under Video Output xVid (but which configuration? Constant Rate? Quantizer? and quality at default 20?)
- under Audio AAC (FaaC)
- under Output Format are 2 MP4 options, Muxer and Muxerv2
2. i have 2 parts i wanna glue together, eg. part1 and then part2 without pause (or small 1 second maybe) to attach to part 1. is this possible with avidemux?
thanks very much ii hope you can help me!
1. CHoose copy if you want lossless mode. Or do you want to shrink the video?
ahhh ok thanks! 1 video i got has some subtitles, what should i choose there? cause in copy i cannot add subtitles i think?
EDIT: for one i wanted 2 parts to glue together (open part1 then append part2 i learned from youtube just now), there i used
Video output COPY
Audio output COPY
Output file MP4 Muxer v2
but then an error pops up, i dunno why, it says it "MUXER Cannot Open" but in the preview i could play the video ?!?!??!?Last edited by VideoNoob123; 6th Oct 2014 at 07:15.
And this is not video STREAMING. Moving you to our video conversion section.
If you want to hardcode/burn in subtitles must you choose a codes yes. I would use h264/avc video if you are making a mp4. And AAC audio.
