Nothing plays sound in aviutl ONLY ? or PC ?
Make sure in aviult you didn't mute the audio, or check filter+ => volume level; there is separate control for volume in playback window also
				Results 31 to 36 of 36
	This is the second report I notice concerning a sudden breakdown of AviUtl... while I didn't ever get this myself even with tons of debug-mode plugins....
 really puzzling.
 If anyone encounter this problem, please submit the following to the "AviUtl support thread" in the "Editing" board:
 1> aviutl.ini
 2> exedit.ini
 3> MD5 of: aviutl.exe, exedit.auf and lwinput.aui
 4> Whether it will work again if you copy just aviutl.exe and exedit.auf to another folder and run from the new folder
 5> Whether loading a simple Uncompressed AVI (Progressive) with PCM audio works normally
 6> OS and the Antivirus software you're using
 7> System locale for non-Unicode programStopping development until someone save me from poverty or get me out of Hong Kong...
 Twitter @MaverickTse
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
