hey guys
sorry for being a noob but I've just installed Gabset MP4 splitter into my system
but I have no Idea about how can I use it .. is it a command line tool or a GUI or what ??
thanks
Results 1 to 11 of 11
It's GABEST, not "Gabset".
It's a DirectShow filter.
Just like Haali, it sucks when compared to LAV Splitter. -
Yeah, it's a demultiplexer, in other words.
Were you looking for a tool to actually split/cut MP4s?If cameras add ten pounds, why would people want to eat them? -
I was told that it's able to Demux and extract subtitles from MP4 files.. I've just successfully Installed and Registered it and I also installed graphStudio too now I have not Idea how can I use it to Demux
Use mp4box or a gui for it like mymp4boxgui as suggested above.
thanks for answer
but I've already tried MP4box and mymp4boxGUI and Yamb
and my question now is
So MP4 Splitter can't be used to Demux and extract subtitles from MP4 files ? -
No, you can't use gabest mp4 splitter to demux anything.
First I tried with LAV Splitter, however neither VSFilter nor dump.ax work with its subtitle pin
Then I registered MP4Splitter.ax, and this time:
a) VSFilter detects and displays correctly the TTXT stream
b) BUT dump.ax extracts only the "pure" text, without any timing or structuring info
how can I demux using MP4Box Command Line tool (remove the text stream from the video)... I can't find this option in YAMB and for some reason I'm not able to use MyMP4BoxGUI ... what is the code required to do that using the command line tool in CMD? (Like -add, -ttxt, -raw)
