http://www.digitalcameraworld.com/2014/09/15/samsung-nx1-price-specs-release-date-confirmed/
http://www.dpreview.com/previews/samsung-nx1
40Mbps 4k 4:2:0 HEVC
UHD 3840×2160 (30fps Only), 4K 4096×2160 (24fps Only)
First wave of consumer accessible hardware recorders coming out
~ US$2110
Results 1 to 14 of 14
Hello poisy!
4K camcorder with (around) 1100 *1000 pixel real visible resolution? That catastrophic real (visible) resolution wouldn't be a suprise, because it is only just a DSLR. The very high resolution sensor causes problems for sharp picture, because the device try to downsample downsize the high resolution image to 4K picture. Enormous quality loss. -
Hi!
It is interesting to see the price tag / description of the chip
It would be possible to download the result of a camera
The ideal situation: the sensor has the same resolution as the output video. In this case there is no need for quality destroyer resize algorithms. By this way, the size of individual pixels are the largest on the case of the same sized sensor, which can collect more light.
I wonder how long it will be before early adopters come here crying "I can't edit my 4k hevc footage!".......
Curious to see how well the h.265 hardware encoder fares. Probably not good, just like the h.264 hardware encoder does. Samsung is not known for quality cameras anyway.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I have tried out the the Samsung NX1 at B&H. They had one in stock and was outputting the 4K video to a 4K TV. Even though it was heavily compressed 4K video it looked super. Almost 3-D like compared to 1080p. I saw a good video of the Samsung NX1 Camera specs and release date here.
So much for "catastrophic quality destroying"...
@Stears555, I guess you've never heard of the well-known technique of DOWNSAMPLING as a successful tool for perceptually increasing "quality" while adding anti-aliasing (assuming the downsampled version doesn't need to be resized up again).
Scott -
You can download NX1 4k source video clips here:http://www.imaging-resource.com/news/2014/11/19/samsung-nx1-4k-video-samples-and-new-f...ailable-for-do
Has anyone else have success editing these hevc 4k clips? I tried Vegas (version 10), but it doesn't support hevc. Maybe newer versions have updated input plugins?
Anyway I can edit them in Aviutl and Virtualdub under Windows. ShotCut can edit them under Linux. All use ffmpeg based input plugins. It may be OK with these small samples, but I don't know if large clips may cause crashing...
Certainly you can batch transcode these clips into avc, mpeg-2 or whatever using ffmpeg. You'll need to use the 64-bit version to avoid memory error.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I have had good results using Cyberlink PowerDirector 13 for work with H.265 4K video. My i7 laptop has no problems converting 4K to 1080p .mp4 . It also plays well with XAVC-S files from my RX100 M3. Takes a 1/4 of the time to convert versus Sony Vegas Pro.
So are you editing the clips in native 4k resolution HEVC, then downsizing to 1080p on export? Or are you transcoding the source into 1080p AVC before editing?
It sounds to me like you are transcoding to intermediate, in that case ffmpeg is a much better choice......Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I'm editing the clips in native 4k resolution. Then compressing into lower grade 1080p .mp4 for sending files. PowerDirector 13 will edit the native file.
Sorry, I stay away from s/w that demands my name and email simply to try it out! By the looks of it, PowerDirector 13 seems like it is designed for dummies anyway. I'll pass thank you...
If you want to edit 4k HEVC files from that camera, read this thread: https://forum.videohelp.com/threads/368684-Editing-4k-HEVC-footage-%28Samsung-NX1%29
