Hi all,
I have a Canon DSLR and have got the Magic Lantern firmware.
I have asked on thee ML site but they are a little too in depth for a noob like me to comprehend.
Can anyone advise me on the workflow, what tools to use (Free preferred) and authoring.
I think that the format of the ML RAW files are .MLV.
I do prefer written instructions rather than yortube clips.
Any help would be gratefully received.
This blessed plot, this earth, this realm, this England.
I would prefer to be able to import to either Sony Vegas 10 or Adobe After Effects CS6.
I intend to use either of the above to create a video both DVD and online.This blessed plot, this earth, this realm, this England. -
Very explicit instructions starting halfway down this page:
http://hackermovies.com/hackermovies-magic-lantern-raw-workflow-guide
Honestly, if you're going to DVD (standard definition) or online (heavily recompressed,) you're probably better off using the native files and not messing with RAW. If it's a learning experience only, or you have truly miserable exposure control, by all means go for it.Last edited by smrpix; 4th Oct 2014 at 13:36.
