  1. On a mac running Mavericks I can't hear the audi to mp4 movies. Quicktime 7 dosen't seem to work. Same movie works fone on Snow Leopard.
    USA
    Probably better asked and answered in our Mac Forum. Moving you.
  3. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Use VideoSpec or iMediaHUD to get more information about at least one or two of the videos and post the results here.
    You might also consider using a player other than Quicktime, like MPlayerX or VLC.
  4. …should be related to audio codecs (the one into your mp4 is not handeled by your player, eg: ac3 audio in mp4)
    Your previous system had some plug-ins to enable readout of your audio contents
    but your newest have not , so:
    - install some plug-ins like Perian, and continue to use QuickTime Player 7 as reader (Notice: do not use QuickTimeX, it does not use your plug-ins)
    - or use another reader like VLC
    bye
    For DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
  5. Originally Posted by Ai Haibara View Post
    tryed both still can't hear audio ona mp4 video.
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Then, something else is wrong, and this is where the information dump on one or more of the videos might have helped. Do they use AC3 audio, for example?
    Are you sure you have your sound output/speakers set up correctly in Mavericks?
  7. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    ...okay, then, do you have any problems playing multichannel/surround MKV files?
    I find it odd that your system would only not play audio for MP4 files, even on players that don't use the system architectures. If you take the exact same files from the Mavericks system to another system, do they play properly? (I'm wondering if the copies on the Mavericks system might be corrupt in some way. Doubtful, but I suppose anything's possible.)
