First I'd like to thank everyone for any help they can give me. I have succesfully encoded and burnt a VCD...strange thing was after encoding, my file was about the same size as my original mpeg file. Kinda makes me think the original mpeg may have already been in VCD format.
How can I check mpeg files I currently have to see if they already match vcd, svcd, or xsvcd format? I've searched around and haven't really found any other questions like this. I'm so new to this perhaps I have overlooked a simple solution. Is their a program that I can load a file into and have it simply tell me if the file is already correctly encoded?
Thanks for all your help!
I dont know how it goes neither but i always get the same size when I encode too
http://www.medialab.se/mpgp_100.zip
That tool will tell you resolution, framerate, video bitrate, audio bitrate, and audio sample frequency, very useful (it is also in the TOOLSsection of this website).As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
DIVX3 on Danelec so easy hdmi ***** newbie question
By fraguil in forum Video ConversionReplies: 2Last Post: 6th Sep 2011, 05:56 -
Easy Question..Make duplicate of movie DVD
By WareISChris36 in forum DVD RippingReplies: 4Last Post: 23rd Jul 2011, 15:43 -
Easy Question.. Convert mkv to DVD9
By WareISChris36 in forum Blu-ray RippingReplies: 1Last Post: 21st Jul 2011, 16:22 -
Hopefully an easy question about cutting and joining video with Virtualdub
By crumbworks in forum EditingReplies: 4Last Post: 18th Oct 2010, 15:21 -
You Tube Question... (should be easy)
By greenstrat in forum Video Streaming DownloadingReplies: 1Last Post: 20th Jul 2009, 23:47
