  1. Hi cats,
    please I have set my camera as fpt site
    whit flashfxp I can see the content of a disc inserted in camera with this:
    so to have access at the camera
    username: admin
    password: pdw-f800
    I would like do a batch script that access to the camera automatically and copy the file c:\c0020.mxf into the dir \\clip of the xdcam disc of the camera
    How can I do? thanks
  2. Hi !
    Something like that could help you :
    Create a batch file copytocam.bat
    echo user admin pdw-f800 >cmds.ftp
    echo cd /clip >>cmds.ftp
    echo put c:\c0020.mxf >>cmds.ftp
    echo bye >>cmds.ftp
    ftp -d -n -i -s:cmds.ftp ip_address_or_name_of_camera_here
    del cmds.ftp
    This will copy the c:\c0020.mxf of your hard disk to the /clip directory of your webcam.
    The first 4 rows create a set of commands for ftp. Attention, the first one has a single > (to truncate existing file) and 3 nexts have double > (>>) to append the file
    Replace ip_address_or_name_of_camera_here with eighter something like 192.168.1.45 (you camera IP address) or the name like ftp.mywebcam.org.
  3. Click image for larger version
ID:	27829 IT WORKS! thanks!!!
    please can I ask you another thing?
    now I would like the batch to this:
    check all .mxf files in the folder "clip" of the webcam and try to put the c:\c0020.mxf into the "clip" folder of the camera, but if there are anhother file called C0020.mxf ----> rename the C:\C0020.mxf as C0021.MXF (or C0700.MXF or C0701.mxf ... etc. until C9999.MXF) and put it on the folder "clip" of the camera
    How can do this?
    thanks
  4. DECEASED
    Jun 2009
    Heaven
    You like to be spoon-fed, and yes, that sux pig time.
  5. Member DB83's Avatar
    Jul 2007
    Siamese twin cats.
    "now I would like the batch to this:
    check all .mxf files in the folder "clip" of the webcam and try to put the c:\c0020.mxf into the "clip" folder of the camera, but if there are anhother file called C0020.mxf ----> rename the C:\C0020.mxf as C0021.MXF (or C0700.MXF or C0701.mxf ... etc. until C9999.MXF) and put it on the folder "clip" of the camera"
    I would swear I read the same request in another topic.
    Some cat needs to read the forum rules about cross-posting.
  6. oh, I forgot to specify the "please enter cats only, thanks"
    in fact: in this tread I ask a different thing. The batch have to enter in ftp site, see a list of .mxf files and choose a filename that are not present in that ("clip") folder, possibly starting from C1700.mxf (if alrerady exist C1700.mxf, it have to choose C1701.mxf, but if C1071.mxf is already present it have to choose C1702.mxf). So for example, the c:\c0020.mxf have to be renamed in C1700.mxf and put into the "clip" folder
  7. Member DB83's Avatar
    Jul 2007
    Keep repeating it and you will believe it.
    But if you can NOT adopt what was already said in the other thread to this scenario then I really am sorry for you.
    'Spoon fed' is two many words
