A friend of mine is an interior decorator. She has appeared on a show called Cityline and is trying to grab the clips of her appearances on the CityTV website. I was able to grab a bunch of the clips, but some of them are encrypted differently (probably because the dates are spread out a fair bit). The Cityline folks told her to screencapture the videos, but I was having framerate issues with that.
I have tried IDM, RTMP Explorer, RTMPdump, StreamTransport to no avail. I used URLSnooper2 to grab the stream URL too. I know there are various command line settings I can try in RTMPdump. I have not done that because I don't know enough at this point.
The links to the videos are:
http://www.cityline.ca/video-archive/2680558193001/
http://www.cityline.ca/video-archive/2680552648001/
http://www.cityline.ca/video-archive/2878562448001/
Anyway, I was wondering if anyone has any advice on how to grab these or if I should ask/research this question elsewhere, where you would recommend?
Thanks, Bill.
Results 1 to 1 of 1
