What’s the best way to burn the video a SJ4000 takes onto a Blu-ray as a Blu-ray movie? Got a Blu-ray burner just need to know what software converts the files it produces correctly without any loss of quality, thanks.
Post the details from one of the mp4/mov files. Use mediainfoxp, open the video and then copy all details. So we can check if it's blu-ray compliant(no video reconversion).
Or just try a good authoring package like tmpgenc authoring works. -
Thanks for a quick reply!
This is the info I got from one of the files I want to burn to a Blu-ray movie:
General
Complete name : C:\Users\Desktop\4.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 564 MiB
Duration : 4mn 57s
Overall bit rate : 15.9 Mbps
Encoded date : UTC 2004-01-01 00:00:00
Tagged date : UTC 2004-01-01 00:00:00
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=15
Codec ID : avc1
Duration : 4mn 57s
Bit rate : 14.7 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.237
Stream size : 522 MiB (93%)
Language : English
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 4mn 56s
Bit rate mode : Constant
Bit rate : 512 Kbps
Channel(s) : 1 channel
Sampling rate : 32.0 KHz
Bit depth : 16 bits
Stream size : 18.1 MiB (3%)
Language : English
Tagged date : UTC 2004-01-01 00:00:00 -
30fps is not a valid BR frame rate.
You could slow it down in Avisynth with a simple script such as:
QTInput("yourmovie.mov")
AssumeFPS(30000/1001)
(You will need to google for the QTInput plug-in as it isn't standard)
Then load your original file into Audacity to change the audio speed to match.
Then load the Avisynth script and the Audacity output into an authoring app like TMPGenc Authoring works.
(Or just load it into TMPGenc Authoring Works as Baldrick suggested and live with the frame blending. There is no lossless way to get this file onto a BR.)Last edited by smrpix; 2nd Oct 2014 at 09:21.
As per MediaInfo, the audio sampling rate ain't compliant either.
Progressive 29.97fps or progressive 25fps isn't strictly according to spec for 1920x1980 BR. I know what the videohelp listing says in https://www.videohelp.com/hd#tech, but strict per-spec BluRay at those frame rates is supposed to be interlaced. Some players might handle it correctly, others might play as interlaced anyway. Motion and pans with 29.97p might look OK with some setups, not so OK with others.
What about GOP's? Doesn't "M=1, N=15" mean there are P frames only, no B frames? But sometimes those "M, N" numbers look different in many specs.
The strict encoding specs are here: http://forum.doom9.org/showthread.php?t=154533Last edited by LMotlow; 2nd Oct 2014 at 09:37.
- My sister Ann's brother -
Probably a good idea, Baldrick, nice work. I've communicated with a number of people about the doom9 version, and they say that when they stick to the strict specs they have no problems with BR disc. BR for PC play, now, that might be a different story. There are PC media players that can handle just about anything, I guess.
I note that TMPGEnc was mentioned in an earlier post in this thread and elsewhere. I've used their stuff for years, and they always struck me as being fussy about proper MPEG/BD/AVCHD structure for standard discs. They'll let you make oddball video for PC playback or the web, but they get kinda rude if you try to stretch non-compliant media too far.Last edited by LMotlow; 2nd Oct 2014 at 16:28.
