I'm using smartripper -> DVD2AVI -> VAPFI > VDub -> TMPGenc and everything works find except for one problem. I'm using the VobSub filter in VDub and I can geneterate the subs but most of them are 'multi-colored' sort of like 'colored TV static.'
Every now and then some of the subs are the normal yellow but most are not. Any ideas? I've done this before without problems (hell did Traffic a few days ago) nothings changed system wise, and settings I should look at?
Thanks in Advance
Ok, d/load the old VobSub 1.46 (was running 1.55) and that fixed everything. When will I learn that upgrades aren't necessary if everything is already working fine
Sorry for the post, but maybe it'll help someone else.
Vejita-sama, thnx for the heads up...i dled the older version of vobsub and it helped...there was 1 line that had the multi-colored stuff (of course not nearly as bad as what happened with yours) but still would be better if none of the subs had any multi-colored stuff
anywayz...dled the older version and worked well..
VobSub extracts subs but don't display
By den207sco in forum SubtitleReplies: 6Last Post: 23rd Jun 2009, 09:12 -
Rip hard-coded subs from avi - VirtualDub filter and SubRip problems
By jujuandhuhu in forum SubtitleReplies: 4Last Post: 25th Oct 2008, 15:16 -
How do I make a filter for VDub
By blaze01 in forum Newbie / General discussionsReplies: 4Last Post: 4th Mar 2008, 17:16 -
Vdub Filter Chain
By christopheramos in forum Video ConversionReplies: 16Last Post: 3rd Sep 2007, 08:57 -
TMPGenc Xpress 4/VobSub cannot load .avi with subs
By varu in forum SubtitleReplies: 3Last Post: 14th May 2007, 19:26
