    Aug 2008
    Bangladesh
    Hi Guys,
    Please see the image of a video file song. I just want to remove the selected texts scrolling continuously from left to right.
    Please explain & mention the software...
    ~r
  2. You can't delete it. It's part of the picture.
    Since the text is on a black bar you can mask it with a matching black bar -- but I don't think that's what you're asking for.
  3. Inpaint algorithm but don't expect miracles (can be substituted by resize/blur in this case - combine 1 line before and after black rectangle as one video then resize this video in vertical direction and blur in horizontal direction and finally overlay over rectangle)
  4. You can give it a try with AviUtl using the mtDeSub plugin that use inpainting.
    Very slow though, be warned.
    A much faster way would be cropping then resizing the video.
    Stopping development until someone save me from poverty or get me out of Hong Kong...
    Twitter @MaverickTse
    Aug 2008
    Bangladesh
    Hi,
    I will try to cut down (Crop) the selected part & the total bottom part, so whats the best soft I can do that?
    And I want to add some text in the bottom & left corner like -
    Text1 - XXXXX
    Text1 - XXXXX
    Text1 - XXXXX
    ~r
