  1. Hi ya Guess what i am new here Prob the wrong place but hey I am not here to annoy but just get a quick answer out of you techies.
    I am in the process of buying panasonic pt ae8000 projector. I have a cheap full hd freeview box, will it make any difference if I buy an expensive one to the picture. As full hd is full hd. The playing device e.g tv or projector makes the difference otherwise no one would buy led tvs. As hdmi cables make no difference
    http://www.expertreviews.co.uk/home-entertainment/1292371/expensive-hdmi-cables-make-n...absolute-proof
    If i download 3d films I guess you need a 3d player to watch them if burnt?
    I have blu ray player and xbox360
    Thanks for any help
  2. Member turk690's Avatar
    Jul 2003
    ON, Canada
    The PTae8000 is a highly regarded projector, and I'm satisfied with mine. However, on another unit that belongs to someone I recommended it to, with the picture on a 110" screen, the red panel is ever so slightly missaligned (possible half a pixel out give or take). It's not a (very) obvious problem but just examine yours out of the box and see. Yes, you specifically need a 3D blu-ray player to watch 3D films.
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
