Results 1 to 9 of 9
  1. Hi cats,
    because seems to me cannot work the simple "OR" in a batch, I wonder:
    supposing defined %variableA% and the %variableB%
    if "%variableA%"=="1" OR if "%variableB%"=="1" --> execute ....
    How is the correct way to use the OR command?
    OR command acts also in the case one of the 2 variable are not defined?
    PLease I should have another questions:
    I have to tell to the batch
    IF the %V_Height% value is greater or equal 720 ---> set the HD format switch =1
    This
    if "%V_Height%" GEQ "720" (Set "HDformat=1")
    seems recognize when %V_Height%=720, but don't set HDformat=1 also when %V_Height%=1080.
    Now: 1080 is greater (or no?^^) than 720... so why the HDformat don't assume "1"?
    thanks
    Sep 2012
    Australia
    Lose the double quotes, otherwise they're compared as strings and 7 is more than 1.
    -edit- You might want to check if V_Height is empty first.
  3. Originally Posted by ndjamena View Post
    ahnn, thanks
  4. you can make these two lines to perform IF OR IF execute something:
    if "%variableA%"=="1" --> execute ....
    if "%variableB%"=="1" if not "%variableA%"=="1" --> execute ....
  5. Originally Posted by marcorocchini View Post
    Now: 1080 is greater (or no?^^) than 720... so why the HDformat don't assume "1"?[/B]
    Because of the way the character value of the string is parsed, the position of the character matters i.e.
    1080 is smaller than
    720 because 1 is less than 7
    1080 is greater than 0720
    Edit: Just noticed ndjamena's post, he's totally right about comparing pure decimal numbers.
  6. yes I understand, and the OR command: maybe it don'exist jet in windows 8.1?
  7. Sorry, it's just that Al gave you the answer. There is no OR command in CMD or COMMAND, it is implied in the way you sequence the commands in your batch file.
  8. for batch problems I always use search engines, two words first "windows batch" following shortly what you want, possibly including command, it mostly brings you to stackoverflow.com, like in this case "windows batch if or" , where duckduckgo for example gives this as first option. Using some kind of switch for IF OR scenario (if "your execute" is long or more complex)
    FOR ..... DO (
      set "TRUE="
      IF cond1 set TRUE=1
      IF cond2 set TRUE=1
      IF defined TRUE (
      ) else (
    that site is a good source for codes, you do not have to have that else there ...
  9. ahn mmmmm I keep in mind ^^
