Hi
i have seen in many video
and i like the smoke effect with the text SuanEffects
you can see here in the beggining
http://youtu.be/83B4vLiyFeQ
may i know which program can do it? the black smoke effect and the text
thanks
				Results 1 to 30 of 41
	Someone probably will know on here.
 But you could always post a comment on his video or send him a tweet on his twitter (as he's active on that).
	You will never be able to do that unless you're a motion graphics artist. Doesn't matter what software you obtain. It's not a canned effect, it's custom made from the ground up.
 People that do that will never help you learn because that's their bread and butter. Just like an artist or magician will never reveal their methods.
 Sure, After Effects, Blender, Cinema 4D, Hifilm, Boris, all have the tools. But the mechanics of building it out is a very steep learning curve. You're better off to buy an effect somewhere.
 Not trying to be negative, just realistic.Last edited by budwzr; 29th Sep 2014 at 19:02.
	Oh come on.... Mr. Negative
 But After Effects, Trapcode Particular are the usual suspects. This type of effect is very common you should be able to find many similar tutorials
 oh wait.. what is this ?  anyone recognize this ? Hahaha anyone recognize this ? Hahaha
 http://www.youtube.com/watch?v=0_rDw_5mE8Q
 You can even download the template
	Oops, never mind. Poisondeathray beat me to that AfterEffects tip. - My sister Ann's brother
	Hahaha, that's like watching a canvas painter draw a portrait and telling you "OK, just put some paint here, and smudge it up there, and there you go!
 I'm not like you guys, that everything is doable, and a commodity. I value and appreciate the artist's skill.
	That effect (and many similar to it) is all over the place. Even the OP says so "i have seen in many video ..."
 You should appreciate the artists' skill and ideas if they are original. Not some rehash of a tutorial. Then it becomes mechanical. "SuanEffects" didn't even change the friggen color scheme LOL
	I'm just sayin', whether it's plagiarized doesn't matter. Of course art is plagiarized all the time. You still need a ton of experience. You guys did your job pointing in the right direction, and I'm adding that it's still going to be a long slog.
 Maybe the OP is a budding particle guru that will take the ball and run with it. If so, I wish him well.
 OK I agree you need to know the basics first . If OP doesn't know what a "keyframe" is, then there is some basic learning to do first
 But in the grand scheme of things, I would categorize this on the "simpler" side of your "typical" after effects project . It's actually not that involved.
 The fact that you see this type of particle reveal or ink splatter reveal all over the place should suggest that it's quite simple to do. There are many of tutorials just like it or very similar effects . You don't even have to do the work, just download a template and customize it (at least change the color scheme LOL )
	There are many ways to measure success. You just have to find your own yardstick.
	Though not as clean, you can do it for free with Aviutl. There are limited particles to choose from. I would have to create my own custom particle to better simulate that smoke/ink effect.
 Here I just used one of the existing particles for a quick simple test.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
	It's a lot more than custom particles. In fact, smoke is included already in probably all the particle generators. You don't need to create it. The tricky part is the choreography and physics involved.
 Also, the tools are numerous and don't share the same toolbox. Nor do all the tools fit on the screen, so you have to dig around a lot. Meanwhile, the keyframed rows get denser, more complicated, and tedious. One mistake and you may not even be able to find the error.
 I'm trying to learn this stuff myself and it's a slow process to absorb. You have to learn a whole new vocabulary and ways of envisioning everything. It's like one of those machines at the restaurant with the crane that drops down to pick up a toy and you only have controls outside the cage.
 It's frustrating and you have to have a knack for it, or wait for your knack to come. Hahaha. So far my knack hasn't evolved.Last edited by budwzr; 30th Sep 2014 at 01:12.
	I was considering a lynda tutorial too. Let us know if it helps.
	hi
 there are so many lynda tutorials , that i'm consindering which should i buy...
 maybe Premiere Pro CC Essential Training and After Effects CC Essential Training (even there is a lot of cinema 4d videos ) )
 they should teach me something , i hope
	do you know there are a lot of things that you can not find in lynda tutorials
 for example i would like to know if i can use an external encoder
 for example create a project with premiere or after effects , and use an external encoder to render it , in short a program like TEncoder
	hi
 i watched the all movie
 but blender looks harder then after effects
 maybe i'm wrong
	As i understand you are not interested in pixel to smoke or similar to this http://www.youtube.com/watch?v=2CGOh-jb4QM#t=255 (watch approx 50 sec to understand effect) - in video example provided at beginning it is just smoke like (or rather particle effect that is similar to dye placed on liquid - more dense than smoke particle in air) that covering some string and string is removed (faded to background) this effect should be way easier than real pixel/objects particle transformation).
 And yes, Blender is not easy but for sure is for free and it offer quality comparable to way more expensive software.
	[QUOTE=pandy;2348770] well i like the begining of the video http://youtu.be/83B4vLiyFeQ
 it's nice to start a personal video
 i agree 100% , blender is an amazing program and it's FREE , would like to know how use itAnd yes, Blender is not easy but for sure is for free and it offer quality comparable to way more expensive software.
 i gave a look to after effects and seems easier then blender
 don't know why, maybe because i'm used to work with other adobe programs
 Blender is primarily 3D software, AE is really "2.5D" (it deals with flat layers like photoshop, although it has z-space, it's 2D layers in 3D space). They aren't really comparable. There are plugins that give AE more 3D like functionality like Element3D .
 Blender is very powerful, but has a poor interface/GUI. It's really an incredible program for free
 AE has 2 particle generators built in, but the one used in that video is Trapcode Particular. It's really the "gold standard" for 2D particle generators. Many of the effects you seen in movies, TV, have use it for years.
 The Lynda Essentials would be a good place to start, but there are lots of free beginner to advanced tutorials at videocopilot.net, aetutsplus
	You might like HitFilm2.
 I'm pretty sure the way they made that "smoke" pattern is really more complex than it appears. I think they're using the concept of mobile emitters. Each particle releases sub-particles that decay and loop differently.
 Imagine it like a squadron of bombers flying by and each one releasing bomblets that have their own flight characteristics. The bomblets have a short decay time and do a little spiral with a short contrail.
 And the motions of the whole cloud itself is maybe a deform, or perhaps a deflector. There are lots of invisible forces that can be applied. That's where the art comes in.
 Update: I watched the video and what I wrote above is wrong. He used a Turbulance force to create the smokey look. I'm intrigued by this, and got some good motivation to try it myself.Last edited by budwzr; 30th Sep 2014 at 17:49.
 You can from premiere, with frameserving with advanced frameserver or debugmode frameserver; but no frameserver exists from AE.
 I recommend exporting an RGB "master" from AE , usually an image sequence, which you use then to encode for several versions of the video. You might have several destination formats, eg.. maybe one for devices, one for blu-ray, one for web, maybe different resolutions etc... So instead of having to re-render all the slow effects, calculations, multiple times - you have a high quality "master" archived. Final format video encoding is slower when you have to do it directly from AE, because in addition to rendering all the effects, encoders often have a "lookahead" function to reference past/previous frames (temporal compression), not I-frame or image sequence formats that only look at 1 frame at a time
 Additionally, if something crashes , your previous rendered work is saved with an image sequence. If you use a video format like AVI, MOV etc... often it's corrupted, you have to start all over. Also, if something changes in your project, maybe you want to change small part of the animation timing, it's easier to replace those images. "Video" formats don't support 32bit linear workflow either, which is used in all high end VFX work - typically EXR is used. For those reasons, VFX artists typically use image sequences, especially out of 3D programs where you uses multiple passes and layers for compositing.
 Cool - post your settings when you've figured it out and other Hitfilm users can benefit
 But I suspect it doesn't have enough controls or options compared to Particular
	HitFilm2 has a turbulance force, but like you said, it lacks fine controls and options. You get what you pay for.
 I made this in HF2 from scratch. It's different, but the style is similar. I used the Particle Array instead of Emitters. Not much learning curve.
 https://www.youtube.com/watch?v=gyCo8R1vyIc&feature=youtu.be
 I think there's enough in HF2 for the OP to get his beak wet, at least. It's worth it to check out the free HF tutorials. The artist over there, Axel, is very knowledgeable, and they try to cover a lot of topics. And the tutes actually teach something, not just breezing through it real fast, but every step.Last edited by budwzr; 30th Sep 2014 at 17:47.
	This one is a little better. I made the custom Ink/Smoke by simply drawing some scribble and save as png.
 Yes the video version is a lot smoother.....Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
	Mine is easier to do, although not quite the same. I can't do the other one, my software isn't up to snuff. Looks like AviUtil can't cut that kind of mustard either, hehehe.
 I'm in the same boat as Racer. Not enough cajones in the software. I'm suspecting PDR is going to come in here with something and blow us all away.
 Made with HitFilm2 Ultimate - Pixel Array Tool
 The way I got this GIF smooth was I rendered it out of Vegas at 1fps, down from 30fps, to a PNG Sequence. Then I used Easy Gif Animator to assemble it.Last edited by budwzr; 2nd Oct 2014 at 23:45.
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
