  1. O_o;
    how should i explain this?
    first of all, i'm trying to burn anime to vcds, (if that helps at all) and the subtitles are being clipped.. thus...
    using the TMPGE encoder to convert avi files to mpg, how can i get it so that it's NOT clipped, like you know those movies with the black border.
    (does this make sense? O_o)
    since i'm a newbie and er.. i know like NO terminology whatsoever.. -.-
    and this is semi-urgent, so.. if you can help, PLS DO!
    ^_^ thank you..!
  2. You mean like the area that the subtitles are on is completely clipped out?
  3. ah..nevermind. i know how to fix it.
    Feb 2001
    Berlin, Germany
    Maybe some more people would like to know how you solved the problem. So if you think it is worth to post, please do.
    Apr 2002
    Florida
    probably the wrong template
    Static is in the minds and hearts of all mankind the sad part is... that we never fully comprehend the concept that is static.
