  1. Hi cats, please can u help a ***?
    consider the attached mediainfo.txt
    General
    Complete name                            : C:\f335\ciro.mxf
    Format                                   : MXF
    Commercial name                          : XDCAM HD 35
    Format profile                           : OP-1a
    Format settings                          : Closed / Complete
    File size                                : 54.2 MiB
    Duration                                 : 11s 760ms
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 38.7 Mbps
    Encoded date                             : 2014-09-18 21:42:26.000
    Writing application                      : SONY Opt  1.20
    Writing library                          : SONY Opt  1.20
    Video
    Format                                   : MPEG Video
    Format version                           : Version 2
    Format profile                           : Main@High
    Format settings, BVOP                    : Yes
    Format settings, Matrix                  : Custom
    Format settings, GOP                     : M=3, N=12
    Format settings, picture structure       : Frame
    Format settings, wrapping mode           : Frame
    Codec ID                                 : 0D01030102046001-0401020201030300
    Bit rate mode                            : Variable
    Bit rate                                 : 35.0 Mbps
    Width                                    : 1 440 pixels
    Height                                   : 1 080 pixels
    Frame rate                               : 25.000 fps
    Standard                                 : Component
    Scan type                                : Interlaced
    Scan order                               : Top Field First
    Bits/(Pixel*Frame)                       : 0.900
    Stream size                              : 49.1 MiB (91%)
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio #1
    Format                                   : PCM
    Format settings, Endianness              : Little
    Format settings, wrapping mode           : Frame (AES)
    Codec ID                                 : 0D01030102060300
    Bit rate mode                            : Constant
    Bit rate                                 : 768 Kbps
    Channel(s)                               : 1 channel
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 16 bits
    Stream size                              : 1.08 MiB (2%)
    Audio #2
    Format                                   : PCM
    Bit rate                                 : 768 Kbps
    Bit depth                                : 16 bits
    Audio #3
    Format                                   : PCM
    Bit rate                                 : 768 Kbps
    Bit depth                                : 16 bits
    Audio #4
    Format                                   : PCM
    Bit rate                                 : 768 Kbps
    Bit depth                                : 16 bits
    Other #1
    Type                                     : Time code
    Format                                   : MXF TC
    Time code of first frame                 : 02:55:41:06
    Time code settings                       : Striped
    Other #2
    Type                                     : Time code
    Format                                   : SMPTE TC
    Muxing mode                              : SDTI
    in a batch script I would like set a enviroment variable theblackcat to 1 IF at the same time are true that:
    --> commercial name = XDCAM HD 35
    --> Frame rate = 25.000 fps
    --> Chroma subsampling = 4:2:0
    If one of this is not true, the %theblackcat% cannot be = 1
    How I can I do? thanks
  2. Code:
    if exist  "%temp_folder%\mediainfo.txt" del "%temp_folder%\mediainfo.txt"
    "%mediainfo%" %1 dumpinfo:"%temp_folder%\unicodefile.txt"
    TYPE "%temp_folder%\unicodefile.txt" > "%temp_folder%\mediainfo.txt"
    set info="%temp_folder%\mediainfo.txt"
    set theblackcat=0& set xdcamhd=unknown& set fps=unknown& set ch_sub=unknown
    findstr /c:"Commercial name                          : XDCAM HD 35"        %info% >nul
      if %ERRORLEVEL%==0 SET xdcamhd=yes
    findstr /c:"Frame rate                               : 25.000 fps"            %info% >nul
      if %ERRORLEVEL%==0 SET fps=25.000
    findstr /c:"Chroma subsampling                       : 4:2:0"                 %info% >nul
      if %ERRORLEVEL%==0 SET ch_sub=yes
    if [%xdcamhd%]==[yes] if  [%fps%]==[25.000] if [%ch_sub%]==[yes] set theblackcat=1
  3. mostly you need to know what fps really is (same like height, width,display aspect ratio etc...), so you can parse real value:
    findstr /c:"Frame rate                               :" %info% > "%temp_folder%\temp.txt"
    set /p string= < "%temp_folder%\temp.txt"
    SET divider=:
    CALL SET after=%%string:*%divider%=%%
    set fps=%after: fps=%
    or height for example
    findstr /c:"Height                                   :" %info% > "%temp_folder%\temp.txt"
    SET divider=:
    set h=%after: pixels=%
    set h=%h: =%
    I had chosen this mediainfo data extraction as oppose mediainfo CLI because cli cannot get all parametrs, not sure what now ...
  4. mmm thanks
