Hi
i have always used avidemux and virtualdub
well , now i'm running premiere pro cc , and i need to load a video , and cut some parts
in virtualdub , i used the direct stream save , because i don't want to re-convert / rendering
i don't want to change the output
can i do with premiere ?
thanks
ps i'm new hope it's the right place
thanks a lot poisondeathray
are all the avi uncompressed DV-AVI ?
googling i foun _http://blogs.adobe.com/kevinmonahan/2012/10/11/smart-rendering-in-premiere-pro-cs6-6-0-1-and-later/
can vegas do it ?
i'm looking for program to do my editing , with more feature then virtualdubLast edited by rama; 25th Sep 2014 at 14:05.
No, DV-AVI is a specific type of video in AVI container
If you don't know what you have, you can use mediainfo (view=>text)
No, vegas is limited to about the same types of video as premiere for smart rendering, but it can do some types of "generic" MPEG2 as wellgoogling i foun _http://blogs.adobe.com/kevinmonahan/2012/10/11/smart-rendering-in-premiere-pro-cs6-6-0-1-and-later/
can vegas do it ?
What sort of editing tasks are you doing exactly ? What kinds of video are you using ?
There are other "smart rendering" editors, like tmpgenc smart renderer , videoredo, solveigmm video splitter - but they are limited to simple editing features as well -
hi
well the videos are
1) video created with my canon 5d mark 2
2) Codec: H264 - MPEG-4 AVC (part 10) (avc1) (i used vlc to do it) and Codec: MPEG-4 Video (XVID)
hiThere are other "smart rendering" editors, like tmpgenc smart renderer , videoredo, solveigmm video splitter - but they are limited to simple editing features as well
they are trial ,one is cheap
are they so superior then virtualdub and avidemux (both free) for simple editing , cut some part of the videos
thanks a lot!
