This is a well known error but I cannot figure it out on my new Lenovo Windows 8.1 laptop, so let me sum up quickly.
I can open a .mov file with virtualdub, but when I play, I get the old "no audio decompressor could be found" error.
If I click "no audio" it plays without audio fine.
I am using virtualdub with ac3, ffinput, quicktime, directshowinput plugins installed, all 32bit. I have 32bit acm ac3 codec installed. They are listed under the audio compression options in virtualdub.
The mediainfo description of the mov file follows. What am I missing?
General
Complete name : D:\1409\FILE0170.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 3.67 GiB
Duration : 37mn 8s
Overall bit rate : 14.1 Mbps
Encoded date : UTC 2008-01-21 16:04:06
Tagged date : UTC 2008-01-21 16:04:06
AMBA :
Video
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=15
Codec ID : avc1
Duration : 37mn 8s
Bit rate mode : Variable
Bit rate : 14.0 Mbps
Maximum bit rate : 18.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.225
Stream size : 3.62 GiB (99%)
Title : Ambarella AVC / Ambarella AVC
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 37mn 8s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 34.0 MiB (1%)
Title : Ambarella AAC / Ambarella AAC
Language : English
Text #1
Format : Timed Text
Codec ID : text
Duration : 37mn 8s
Source duration : 37mn 9s
Bit rate : 480 bps
Stream size : 131 KiB (0%)
Source stream size : 131 KiB (0%)
Title : Ambarella EXT / Ambarella EXT
Language : English
Text #2
Format : Timed Text
Codec ID : text
Duration : 37mn 8s
Bit rate : 19.8 Kbps
Stream size : 5.25 MiB (0%)
Source stream size : 5.25 MiB (0%)
Language : English
