Try DVDFab and copy Ultra HD Blu-rays and DVDs! Or rip iTunes movies and music! Download free trial !
    Apr 2009
    Saudi Arabia
    I owned Panasonic bluray player that I used to play AVCHD discs on it.
    I've upgraded to Samsung 5500 blue ray 3D player and AVCHD disc that used to play on Panasonic is not working on Samsung player
    I encode those videos using multiAVCHD
    Could you please help
    Post the details from one of the avchd that doesn't work. Use mediainfo.
    And maybe it's a dvd media problem. What is the error message if any?
  3. Member Cornucopia's Avatar
    The only BD player that samsung makes with the "5500" # is the BD-C5500 (sometimes with a suffix). The manual makes no mention of compliance with or support of AVCHD, so I can only assume that player is not meant for AVCHD discs.
    (Would have been quicker if you had just given the full, correct model #s)
    <edit>oops, looks like that was premature: different search just brought up a few more...more later</edit>
    ...The D5500 and E5500 does NOT support AVCHD. The F5500 and H5500 DOES. Which one is actually yours?
    Apr 2009
    Saudi Arabia
    F5500
  5. Member Cornucopia's Avatar
    Assuming it isn't a AVCHD v2.0-type disc (which isn't well supported yet), I'd have to guess that it has something to do with how multiAVCHD encoded/authored the disc which proved non-standard.
    MediaInfo might give more clues if there is something obvious in the V/A streams, but otherwise...not much to suggest. Sorry. Some players are more picky than others. That's why it can be helpful to have more than one lying around.
    Apr 2009
    Saudi Arabia
    General
    ID/String : 1 (0x1)
    CompleteName : F:\BDMV\STREAM\00000.m2ts
    Format : BDAV
    Format/Info : Blu-ray Video
    FileSize/String : 3.91 GiB
    Duration/String : 1h 39mn
    OverallBitRate_Mode/String : Variable
    OverallBitRate/String : 5 606 Kbps
    OverallBitRate_Maximum/String : 35.5 Mbps
    Video
    ID/String : 4113 (0x1011)
    MenuID/String : 1 (0x1)
    Format : AVC
    Format_Profile : High@L4.0
    Format_Settings_CABAC/String : Yes
    Format_Settings_RefFrames/String : 3 frames
    CodecID : 27
    BitRate/String : 4 614 Kbps
    BitRate_Maximum/String : 14.0 Mbps
    Width/String : 1 280 pixels
    Height/String : 720 pixels
    DisplayAspectRatio/String : 16:9
    FrameRate/String : 23.976 fps
    ColorSpace : YUV
    ChromaSubsampling : 4:2:0
    BitDepth/String : 8 bits
    ScanType/String : Progressive
    Bits-(Pixel*Frame) : 0.209
    StreamSize/String : 3.30 GiB (84%)
    Encoded_Library/String : x264 core 93 r1542M 5b86182
    Encoded_Library_Settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x12 / me=hex / subme=2 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=9 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=0 / keyint=48 / keyint_min=8 / scenecut=40 / intra_refresh=0 / rc_lookahead=48 / rc=abr / mbtree=0 / bitrate=4614 / ratetol=1.0 / qcomp=0.50 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=14000 / vbv_bufsize=15000 / ip_ratio=1.10 / pb_ratio=1.10 / aq=1:1.00 / nal_hrd=vbr
    Language/String : English
    Audio
    ID/String : 4352 (0x1100)
    Format : AC-3
    Format/Info : Audio Coding 3
    Format_Settings_ModeExtension : CM (complete main)
    Format_Settings_Endianness : Big
    CodecID : 129
    BitRate_Mode/String : Constant
    BitRate/String : 640 Kbps
    Channel(s)/String : 6 channels
    ChannelPositions : Front: L C R, Side: L R, LFE
    SamplingRate/String : 48.0 KHz
    BitDepth/String : 16 bits
    Compression_Mode/String : Lossy
    StreamSize/String : 457 MiB (11%)
    Text
    ID/String : 4608 (0x1200)
    Format : PGS
    CodecID : 144
    Video_Delay/String : 5s 339ms
    Language/String : Arabic
