Hi cats, please can you tell me if I can change the script so that the batch recognize if source is TFF or BFF?
thanks
Code:@rem unless otherwise specified for debugging reasons turn echo off @if "%EMode%"=="" Set EMode=ON @ECHO %EMode% @ECHO off xcopy /y v:\automazioneclip\system\morgan\m3jpegHD.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\morgan\MMIJG32.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\morgan\m3jpegSD.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\x264VFW.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\pvmjpg40.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\morgan\MMIJG30.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\lcodccmp2.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\morgan\m3jpSD.INI c:\windows xcopy /y v:\automazioneclip\system\morgan\m3jpHD.ini c:\windows if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\m3jpegHD.dll c:\windows\SysWOW64 if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\MMIJG32.dll c:\windows\SysWOW64 if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\m3jpegSD.dll c:\windows\SysWOW64 if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\MMIJG30.dll c:\windows\SysWOW64 if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\lcodccmp2.dll c:\windows\SysWOW64 if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\x264VFW.dll c:\windows\SysWOW64 if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\pvmjpg40.dll c:\windows\SysWOW64 md c:\windows\spvideo xcopy /y v:\automazioneclip\system\wavdest.ocx c:\windows\spvideo xcopy /y v:\automazioneclip\system\SamplesDropper.ocx c:\windows\spvideo xcopy /y v:\automazioneclip\system\SP_audio.ocx c:\windows\spvideo xcopy /y v:\automazioneclip\system\dv_grabber.ocx c:\windows\spvideo xcopy /y v:\automazioneclip\system\SP_video.ocx c:\windows\spvideo regsvr32 /s c:\windows\spvideo\wavdest.ocx regsvr32 /s c:\windows\spvideo\SamplesDropper.ocx regsvr32 /s c:\windows\spvideo\SP_audio.ocx regsvr32 /s c:\windows\spvideo\dv_grabber.ocx regsvr32 /s c:\windows\spvideo\SP_video.ocx regedit /s v:\automazioneclip\system\VDreg.reg regedit /s v:\automazioneclip\system\PICreg.reg regedit /s v:\automazioneclip\system\drivers.reg del v:\automazioneclip\output\temp.avi del v:\automazioneclip\output\temp.wav cls SetLocal DisableDelayedExpansion Set "EXTLIST=*.* Set "DoPop=0" Set "ARGLVL=0" Set "FileName-DQ=" Set VD_LOC="v:\automazioneclip\VirtualDub\vdub.exe" set "DestFolder=." Set "WorkFolder=%DestFolder%" rem process the arguments one by one :ARGS rem if there are no further arguments then exit the batch. if [%1]==[] ( if "%ARGLVL%"=="0" ( CALL :GetTargetName EndLocal pause ) goto :eof ) rem wildcard processing Set "FileName=%~1" if "%FileName%"=="" ( SHIFT goto :ARGS ) rem if the argument doesn't exist in the file system in any form skip it. if NOT EXIST %1 ( SHIFT goto :ARGS ) if NOT [%1]==[] if NOT "%FileName:^*=%%FileName:^?=%"=="%FileName%%FileName%" ( for %%w in (%1) DO ( Set /a ARGLVL+=1 CALL :ARGS "%%~fw" Set /a ARGLVL-=1 ) SHIFT goto :ARGS ) Set "FileName=" rem Set search/recursion variables Set "Pattern=%EXTLIST%" Set "STARTLVL=0" Set "FOUNDLVL=1024" rem if the argument is the current directory then process everything in it. if "%~f1"=="%CD%" ( rem echo Processing Directory "%CD%" CALL :START %1 SHIFT goto :ARGS ) rem Test if the argument is a directory, if it is move to it then process everything in it, if not then move to the file's parent directory and process the file. Then return to starting directory. Type NUL pushd "%~f1" 2> nul if NOT "%errorlevel%"=="0" ( if NOT "%CD%\"=="%~dp1" ( pushd "%~dp1" Set "DoPop=1" ) Set Pattern="%~nx1" ) else ( rem echo Processing Directory "%~f1" Set "DoPop=1" ) CALL :START %1 if "%DoPop%"=="1" ( popd Set "DoPop=0" ) SHIFT goto :ARGS :START <CURRENT_ARG> rem Count is superseded by FOUNDLVL but may still be useful for renaming purposes Set "Count=0" rem Process all files in the current directory fitting the arguments search pattern. for /f "delims=" %%y in ('dir %Pattern% /b /od /a-d') do ( if /I NOT "%%~y"=="File Not Found" CALL :Process_File "%%~fy" ) rem if it didn't find anything search all directories instead goto :eof if "%Count%"=="0" if %STARTLVL% LSS %FOUNDLVL% ( for /d %%b in (*) do ( pushd "%%~fb" rem echo Processing Directory "%%~fb" Set /a STARTLVL+=1 CALL :START "%%~fb" Set /a STARTLVL-=1 popd ) ) goto :eof :Process_File <FILENAME> Set /a Count+=1 Set "FOUNDLVL=%STARTLVL%" SetLocal DisableDelayedExpansion if exist "%~dpn1.wav" ( set "Audio=%~dpn1.wav" ) else ( set "Audio=v:\automazioneclip\system\empty.wav") rem Find TimeCode Info Set AUCount=0; for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\virtualdubmod\FFProbe -hide_banner -loglevel fatal -pretty -show_streams -select_streams v:0 -show_entries stream^=codec_type^,r_frame_rate^,width^,height^,sample_aspect_ratio:stream_disposition^=:format_tags^=timecode^,company_name^,product_name^,product_version "%~1" 2^>^&1') DO ( if "%%~g"=="TAG:company_name" set "T_Company_Name=%%~h" if "%%~g"=="TAG:product_name" set "T_Product_Name=%%~h" if "%%~g"=="TAG:product_version" set "T_Product_Version=%%~h" if "%%~g"=="TAG:timecode" set "TIMECODE=%%~h" if "%%~g"=="r_frame_rate" set "Frame_Rate=%%~h" if "%%~g"=="width" set "V_Width=%%~h" if "%%~g"=="height" set "V_Height=%%~h" if "%%~g"=="sample_aspect_ratio" set "V_PAR=%%~h" if "%%~g"=="codec_type" if "%%~h"=="audio" set /a AUCount+=1 ) if "%V_Width%"=="" ( echo ERROR: Video Width NOT FOUND! pause goto :eof ) if "%V_Height%"=="" ( echo ERROR: Video Height NOT FOUND! pause goto :eof ) if "%Frame_Rate%"=="" ( echo ERROR: Frame_Rate NOT FOUND! pause goto :eof ) if "%V_PAR%"=="" ( echo ERROR: Video PAR NOT FOUND! pause goto :eof ) rem Set "V_Q=UD" rem if %V_Width% LEQ 1920 if %V_Height% LEQ 1120 \\ Set "V_Q=HD" rem if %V_Width% LEQ 1280 if %V_Height% LEQ 752 Set "V_Q=MD" if %V_Width% LEQ 1024 if %V_Height% LEQ 608 Set "V_Q=SD" echo Using %V_Q% Mode echo PAR = %V_PAR% echo Frame_Rate = %Frame_Rate% if "%TimeCode%"=="" echo Warning! no TimeCode Found! if NOT "%TimeCode%"=="" echo Timecode= %TIMECODE% CALL :Make_File "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1" echo FATTO echo. echo --------------------------------------------- echo. EndLocal goto :eof :Make_File <VCF_FILENAME> <AVS_FILENAME> <FILENAME> <ORG_FILENAME> rem *** TRY extract audio from .MXF IMX SD FILE *** Set "TokenS=0" IF "%~x4"==".MXF" Set "TokenS=1" IF "%~x4"==".mxf" Set "TokenS=1" If "%TokenS%"=="1" (if "%V_Width%"=="720" (v:\automazioneclip\core\ffmpeg.exe -loglevel fatal -y -i %4 -map_channel 0.1.0 -map_channel 0.1.1 -af "volume=volume=9dB:precision=fixed" "%DestFolder%\%~n1.wav")) If "%TokenS%"=="1" (if "%V_Width%"=="720" (v:\automazioneclip\core\ffmpeg.exe -loglevel fatal -y -i %4 -map_channel 0.1.2 -map_channel 0.1.3 -af "volume=volume=9dB:precision=fixed" "%DestFolder%\%~n1ch3ch4.wav")) rem *** TRY extract audio from .MXF XDCAM-HD 4:2:2 FILE *** Set "TokenS=0" IF "%~x4"==".MXF" Set "TokenS=1" IF "%~x4"==".mxf" Set "TokenS=1" If "%TokenS%"=="1" (if "%V_Width%"=="1920" (v:\automazioneclip\core\ffmpeg.exe -y -i %4 -filter_complex "[0:1] [0:2] amerge,volume=1.5" -c:a pcm_s16le "%DestFolder%\%~n1.wav")) If "%TokenS%"=="1" (if "%V_Width%"=="1920" (v:\automazioneclip\core\ffmpeg.exe -y -i %4 -filter_complex "[0:3] [0:4] amerge,volume=1.5" -c:a pcm_s16le "%DestFolder%\%~n1ch3ch4.wav")) rem *** TRY extract audio from .MXF OTHER TYPE *** Set "TokenS=0" IF "%~x4"==".MXF" Set "TokenS=1" IF "%~x4"==".mxf" Set "TokenS=1" If "%TokenS%"=="1" (v:\automazioneclip\core\ffmpeg.exe -y -i %4 -filter_complex "[0:1] [0:2] amerge,volume=1.5" -c:a pcm_s16le "%DestFolder%\%~n1.wav") If "%TokenS%"=="1" (v:\automazioneclip\core\ffmpeg.exe -y -i %4 -filter_complex "[0:3] [0:4] amerge,volume=1.5" -c:a pcm_s16le "%DestFolder%\%~n1ch3ch4.wav") rem *** TRY extract audio from GOPRO MP4 file *** Set "TokenS=0" IF "%~x4"==".MP4" Set "TokenS=1" IF "%~x4"==".mp4" Set "TokenS=1" If "%TokenS%"=="1" (v:\automazioneclip\core\ffmpeg.exe -y -i %4 -filter_complex "[0:1] volume=1.5" -c:a pcm_s16le "%DestFolder%\%~n1.wav") rem *** TRY extract audio from .MP4 OTHER TYPE *** Set "TokenS=0" IF "%~x4"==".MP4" Set "TokenS=1" IF "%~x4"==".mp4" Set "TokenS=1" If "%TokenS%"=="1" (v:\automazioneclip\core\ffmpeg.exe -y -i %4 -filter_complex "[0:0] volume=1.5" -c:a pcm_s16le "%DestFolder%\%~n1.wav") echo *** from various format to MorganMJPEG AVI SD 720x576i@25fps *** rem ***Make The .vcf Script File*** echo VirtualDub.audio.SetSource^(0^)^;>%1 echo VirtualDub.audio.SetMode^(0^)^;>>%1 echo VirtualDub.audio.SetInterleave^(1,500,1,0,0^)^;>>%1 echo VirtualDub.audio.SetClipMode^(1,1^)^;>>%1 echo VirtualDub.audio.SetEditMode^(1^)^;>>%1 echo VirtualDub.audio.SetConversion^(0,0,0,0,0^)^;>>%1 echo VirtualDub.audio.SetVolume^(^)^;>>%1 echo VirtualDub.audio.SetCompression^(^)^;>>%1 echo VirtualDub.audio.EnableFilterGraph^(0^)^;>>%1 echo VirtualDub.video.SetInputFormat^(11^)^;>>%1 echo VirtualDub.video.SetOutputFormat^(11^)^;>>%1 echo VirtualDub.video.SetMode^(1^)^;>>%1 echo VirtualDub.video.SetSmartRendering^(0^)^;>>%1 echo VirtualDub.video.SetPreserveEmptyFrames^(0^)^;>>%1 echo VirtualDub.video.SetFrameRate2^(0,0,1^)^;>>%1 echo VirtualDub.video.SetIVTC^(0, 0, 0, 0^)^;>>%1 echo VirtualDub.video.SetCompression^(0x6a6d7674,0,10000,0^)^;>>%1 echo VirtualDub.video.SetCompData^(28,"TUpQRxgAAAAAAAAAAgAAAAgAAAACAAAAAQAAAA=="^)^;>>%1 echo VirtualDub.video.filters.Clear^(^)^;>>%1 echo VirtualDub.audio.filters.Clear^(^);>>%1 echo VirtualDub.SaveAVI^("%DestFolder%\\%~n1_SD.avi"^)^;>>%1 echo VirtualDub.Close^(^)^;>>%1 rem ***Make The .avs Script File*** echo FFVideoSource^(%4^)>%2 echo ConvertToYUY2^(interlaced=true^)>>%2 echo src = last >>%2 echo src = src.width==720^&^&src.height==608?src.crop^(0,32,0,0^):src >>%2 echo src = src.width^>720 ^|^| src.height^>608?src.ColorMatrix^(mode="Rec.709->Rec.601"^): src >>%2 echo src = src.width!=720 ^|^| src.height!=576 ? src.IResize^(720,576^): src >>%2 echo function IResize^(clip Clip, int NewWidth, int NewHeight^) {>>%2 echo Clip>>%2 echo SeparateFields^(^)>>%2 echo Shift=^(GetParity() ? -0.25 : 0.25) * ^(Height()/Float(NewHeight/2)^-1.0^)>>%2 echo E = SelectEven^(^).Spline36resize^(NewWidth, NewHeight/2, 0, Shift^)>>%2 echo O = SelectOdd^( ^).Spline36resize^(NewWidth, NewHeight/2, 0, -Shift^)>>%2 echo Ec = SelectEven^( ^).Spline36resize^(NewWidth, NewHeight/2, 0, 2*Shift^)>>%2 echo Oc = SelectOdd^( ^).Spline36resize^(NewWidth, NewHeight/2, 0, -2*shift^)>>%2 echo Interleave^(E, O^)>>%2 echo IsYV12^(^) ? MergeChroma^(Interleave(Ec, Oc)^) : Last >>%2 echo Weave^(^)>>%2 echo } >>%2 echo AssumeTFF^(^)>>%2 echo SeparateFields^(^)>>%2 echo Ev=SelectEven^(^).sharpen(0.20^)>>%2 echo Od=SelectOdd^(^).sharpen^(0.20^)>>%2 echo Interleave^(Ev,Od^)>>%2 echo Weave^(^)>>%2 echo src.framerate^<26 ? src:src.AssumeTFF^(^).SeparateFields^(^).SelectEvery^(4,0,3^).Weave^(^) >>%2 echo AssumeFPS^(25^)>>%2 echo ChangeFPS^(25^)>>%2 echo processing source file %4 rem ***Call VirtualDub*** if NOT EXIST %VD_LOC% ( echo Um, where the hell is VirtualDubMod? pause ) %VD_LOC% /min %2 /s %1 for %%v in ("%DestFolder%\\%~n1_SD.avi") do ( if %%~zv LSS 128 ( echo ERROR!!! Extra Small File Size Detected!!! pause ) ) v:\automazioneclip\virtualdub\cfourcc.exe -i "%CD%\%~n1_SD.avi" -u MJPG -d MJPG DEL %DestFolder%\*.ffindex DEL %DestFolder%\*.VCF goto :eof :GetTargetName Set "FileName=" Set /p FileName=InputFileName .mxf .mp4 or .avi or InputFolder - INVIO per convertire tutto (EXIT esce): rem Add or remove double-quotes if necessary if NOT DEFINED FileName ( Set "FileName-DQ=" goto :DQSkip ) Set "FileName-DQ=%FileName:"=%" if NOT DEFINED FileName-DQ ( Set "FileName=" Set "FileName-DQ=" goto :DQSkip ) if EXIST "%FileName-DQ%" ( if "%FileName-DQ%"=="%FileName-DQ: =%" ( Set "FileName=%FileName-DQ%" ) else ( Set FileName="%FileName-DQ%" ) ) :DQSkip if /I "%FileName-DQ%"=="" Set FileName="%CD%" if /I "%FileName-DQ%"=="CD" Set FileName="%CD%" if /I "%FileName-DQ%"=="EXIT" goto :eof if /I "%FileName-DQ%"=="NOEXIT" goto :GetTargetName if DEFINED FileName ( Set /a ARGLVL+=1 CALL :ARGS %FileName% Set /a ARGLVL-=1 ) goto :GetTargetName
Results 1 to 19 of 19
Depends on what you mean - it impossible to accurately determine actual field order of the content - you have to use your eyes, human intervention
For example, you can have TFF encoded as BFF, or TFF, or progressive. You can have BFF content encoded as BFF or TFF or proressive
i.e. there can be a difference between content field order, and encoding field order -
mmm my cats is nice cats....
for "field order" I mean what I see in the mediainfo: for example I have a .mxf file in dvcam quality that mediainfo say:
General
Complete name : C:\f335\DVcamF335_2.mxf
Format : MXF
Commercial name : DV
Format profile : OP-1a
Format settings : Closed / Complete
File size : 40.6 MiB
Duration : 10s 560ms
Overall bit rate : 32.3 Mbps
Encoded date : 2014-09-19 11:54:18.000
Writing application : SONY Opt 1.40
Writing library : SONY Opt 1.40
Video
Format : DV
Format_Settings_Wrapping : Frame
Codec ID : 0D01030102020201-0401020202010200
Bit rate mode : Constant
Bit rate : 24.4 Mbps
Encoded bit rate : 28.8 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Time code of first frame : 17:07:58:24
Time code source : Subcode time code
Stream size : 30.8 MiB (76%)
Encoded stream size : 36.3 MiB (89%)
Other #1
Type : Time code
Format : MXF TC
Time code settings : Striped
Other #2
Type : Time code
Format : SMPTE TC
Muxing mode : SDTI
Now I would like detect, possibly with ffprobe this scan order, and set the avisynth script so that use the ReverseFieldOrder() plugin ^^ -
But that might be incorrect. I can show you examples that "say" TFF in mediainfo but are actually BFF , others that "say" BFF , but are actually TFF . Others that say "progressive", but are TFF or BFF. ie. Mediainfo is reporting the encoded field order, this is not necessarily the ACTUAL field order of the content. The only way to determine that accurately is with your eyes
Anyways, I don't see how ffprobe can pass field order information on anyways, even if it passes on incorrect or correct information
Unless your source is ALWAYS from a DV cam, or always from some known source...with know field order. Then you can just assume BFF or whatever it supposed to be. But then you wouldn't need a conditional -
ffprobe -i input.ext -show_frames will give you some info like this for each frame
top_field_first=0 is the key that means BFF. =1 would mean TFF. But it isn't always accurate. It reports the encoded field order, which isn't always the same as the content field order. The content field order is the important one, and can only be determined with your eyes, not ffprobe or mediainfo etc... So if you don't mind possible errors, you would have to somehow use that in your script
[FRAME]
media_type=video
key_frame=1
pkt_pts=224
pkt_pts_time=7.474133
pkt_dts=224
pkt_dts_time=7.474133
best_effort_timestamp=224
best_effort_timestamp_time=7.474133
pkt_duration=1
pkt_duration_time=0.033367
pkt_pos=28114440
pkt_size=120000
width=720
height=480
pix_fmt=yuv411p
sample_aspect_ratio=8:9
pict_type=I
coded_picture_number=0
display_picture_number=0
interlaced_frame=1
top_field_first=0
repeat_pict=0
[/FRAME]
mmmm whats a cat
poison please can ffproble retrive the specific information Codec ID : 0D01030102020201-0401020202010200 ?
this is specific of .mxf and DVCAM/mode of the sony pdw-f800 cameras: in this way I'm shure to don't mistake -
But if you only have IMX TFF, and DVCam BFF sources, straight from the camera - then you can use ffprobe to distinguish between them with ffprobe's top_field_first=1 or 0, respectively. Those two have encoded field orders which match the content field order. It's "other" sources that might cause problems e.g. if you get some random interlaced SD file from someone else, and you don't know the workflow history
the pdw-f800 pdw-f335 and many other models of sony do this mess: record alwais in .mxf files but dvcam .mxf files are recorded in BFF
meanwhile IMX and XDCAMHD422 are recorded in TFF, strange but true
so when I transcode with avisynth, each time I have to detect this condition, at least on the .mxf-dvcam mode, and apply the ReverseFieldOrder() to avoiding the mess
I think codec id is specific only of this type of .mxf files, so the batch apply the ReverseFieldOrder() only on .mxf dvcam files.. I think -
But at least files directly from camera are consistent. Their encoded field order matches their actual content field order. ie. you can use ffprobe or mediainfo and it will be correct (most of the time)
And by convention, DV is always BFF, HD is always TFF. So it's expected
Why do you have to swap field order in the first place ? It doesn't matter TFF or BFF, so as long as it's done properly and flagged -
Do you have a small sample of dvcam mxf ? I have samples of your other files somewhere, but not dvcam
yes ^^ I'm uploading
is this
https://www.dropbox.com/s/4lgctkdw78lko4g/dvcam.MXF?dl=0
seems ffprobe don't wont show codec_id
btw, it is not, but if you use ffprobe already, sure, you should be consistent with that
(using this mediainfo)
Code:if exist "%temp_folder%\mediainfo.txt" del "%temp_folder%\mediainfo.txt" "%mediainfo%" %1 dumpinfo:"%temp_folder%\unicodefile.txt" REM unicode have to be changed to ascii, type command does that TYPE "%temp_folder%\unicodefile.txt" > "%temp_folder%\mediainfo.txt" findstr /c:"Scan order : Bottom Field First" "%temp_folder%\mediainfo.txt" >nul if %ERRORLEVEL%==0 SET field_order=bff findstr /c:"Scan order : Top Field First" "%temp_folder%\mediainfo.txt" >nul if %ERRORLEVEL%==0 SET field_order=tff findstr /c:"Scan type : Progressive" "%temp_folder%\mediainfo.txt" >nul if %ERRORLEVEL%==0 SET field_order=none
You can still distinguish it in avisynth if you use FFMS2 . It distinguishes and reports field order correctly and distinguishes between IMX and DVCam
To check you just use info()
So
FFVideoSource("dvcam.mxf")
Info()
or
FFVideoSource("imx.mxf")
Info()
The parity is distinguised correctly in this case (BFF vs TFF)
So you can use if/then in avisynth. This is saying if reported field order is TFF, then return src, otherwise swap field order of src
In this example, i swapped field order with separatefields.trim(1,0).weave(), this leaves you with 1 less field - But there are other methods you can use. Some insert a blank/black field. But there is no "perfect" way swap field order, all methods have drawbacksCode:src = last filtered = src.getparity==true ? src : src.separatefields().trim(1,0).weave() filtered
So again this only works in this case of these two file types (other files, other cameras, other workflows might not have parity detected correctly with ffms2 or other source filters ) -
And another way you might be able to distinguish it in ffprobe is -pix_fmt
IMX50 will be yuv422p, DVCam will be yuv420p -
thanks, because I put on the batch encoder varioius format (mp4, avi ecc..) that I'm not shure of the BFF/TFF tags, for the moment I have to filter only .mxf dvcam that have as codec_id "0D01030102020201-0401020202010200"
I have download mediainfo cli dll ver. 0.7.70.0
and the ReverseFieldDominance.dll: https://www.dropbox.com/s/updh4bjm2cg53ki/ReverseFieldDominance.dll?dl=0
and modify the batch so:
Code:@rem unless otherwise specified for debugging reasons turn echo off @if "%EMode%"=="" Set EMode=ON @ECHO %EMode% @ECHO oFF xcopy /y v:\automazioneclip\system\morgan\m3jpegHD.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\morgan\MMIJG32.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\morgan\m3jpegSD.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\x264VFW.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\pvmjpg40.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\morgan\MMIJG30.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\lcodccmp2.dll c:\windows\system32 xcopy /y v:\automazioneclip\system\morgan\m3jpSD.INI c:\windows xcopy /y v:\automazioneclip\system\morgan\m3jpHD.ini c:\windows if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\m3jpegHD.dll c:\windows\SysWOW64 if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\MMIJG32.dll c:\windows\SysWOW64 if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\m3jpegSD.dll c:\windows\SysWOW64 if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\MMIJG30.dll c:\windows\SysWOW64 if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\lcodccmp2.dll c:\windows\SysWOW64 if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\x264VFW.dll c:\windows\SysWOW64 if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\pvmjpg40.dll c:\windows\SysWOW64 md c:\windows\spvideo xcopy /y v:\automazioneclip\system\wavdest.ocx c:\windows\spvideo xcopy /y v:\automazioneclip\system\SamplesDropper.ocx c:\windows\spvideo xcopy /y v:\automazioneclip\system\SP_audio.ocx c:\windows\spvideo xcopy /y v:\automazioneclip\system\dv_grabber.ocx c:\windows\spvideo xcopy /y v:\automazioneclip\system\SP_video.ocx c:\windows\spvideo regsvr32 /s c:\windows\spvideo\wavdest.ocx regsvr32 /s c:\windows\spvideo\SamplesDropper.ocx regsvr32 /s c:\windows\spvideo\SP_audio.ocx regsvr32 /s c:\windows\spvideo\dv_grabber.ocx regsvr32 /s c:\windows\spvideo\SP_video.ocx regedit /s v:\automazioneclip\system\VDreg.reg regedit /s v:\automazioneclip\system\PICreg.reg regedit /s v:\automazioneclip\system\drivers.reg cls SetLocal DisableDelayedExpansion Set "EXTLIST=*.*" Set "DoPop=0" Set "ARGLVL=0" Set "FileName-DQ=" Set VD_LOC="v:\automazioneclip\VirtualDub\vdub.exe" set "DestFolder=." Set "WorkFolder=%DestFolder%" rem process the arguments one by one :ARGS rem if there are no further arguments then exit the batch. if [%1]==[] ( if "%ARGLVL%"=="0" ( CALL :GetTargetName EndLocal pause ) goto :eof ) rem wildcard processing Set "FileName=%~1" if "%FileName%"=="" ( SHIFT goto :ARGS ) rem if the argument doesn't exist in the file system in any form skip it. if NOT EXIST %1 ( SHIFT goto :ARGS ) if NOT [%1]==[] if NOT "%FileName:^*=%%FileName:^?=%"=="%FileName%%FileName%" ( for %%w in (%1) DO ( Set /a ARGLVL+=1 CALL :ARGS "%%~fw" Set /a ARGLVL-=1 ) SHIFT goto :ARGS ) Set "FileName=" rem Set search/recursion variables Set "Pattern=%EXTLIST%" Set "STARTLVL=0" Set "FOUNDLVL=1024" rem if the argument is the current directory then process everything in it. if "%~f1"=="%CD%" ( rem echo Processing Directory "%CD%" CALL :START %1 SHIFT goto :ARGS ) rem Test if the argument is a directory, if it is move to it then process everything in it, if not then move to the file's parent directory and process the file. Then return to starting directory. Type NUL pushd "%~f1" 2> nul if NOT "%errorlevel%"=="0" ( if NOT "%CD%\"=="%~dp1" ( pushd "%~dp1" Set "DoPop=1" ) Set Pattern="%~nx1" ) else ( rem echo Processing Directory "%~f1" Set "DoPop=1" ) CALL :START %1 if "%DoPop%"=="1" ( popd Set "DoPop=0" ) SHIFT goto :ARGS :START <CURRENT_ARG> rem Count is superseded by FOUNDLVL but may still be useful for renaming purposes Set "Count=0" rem Process all files in the current directory fitting the arguments search pattern. for /f "delims=" %%y in ('dir %Pattern% /b /od /a-d') do ( if /I NOT "%%~y"=="File Not Found" CALL :Process_File "%%~fy" ) rem if it didn't find anything search all directories instead goto :eof if "%Count%"=="0" if %STARTLVL% LSS %FOUNDLVL% ( for /d %%b in (*) do ( pushd "%%~fb" rem echo Processing Directory "%%~fb" Set /a STARTLVL+=1 CALL :START "%%~fb" Set /a STARTLVL-=1 popd ) ) goto :eof :Process_File <FILENAME> Set /a Count+=1 Set "FOUNDLVL=%STARTLVL%" SetLocal DisableDelayedExpansion if exist "%~dpn1.wav" ( set "Audio=%~dpn1.wav" ) else ( set "Audio=v:\automazioneclip\system\empty.wav") rem Find TimeCode Info Set AUCount=0; for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\virtualdubmod\FFProbe -hide_banner -loglevel fatal -pretty -show_streams -show_entries stream^=codec_type^,width^,height^,sample_aspect_ratio:stream_disposition^=:format_tags^=timecode^,company_name^,product_name^,product_version "%~1" 2^>^&1') DO ( if "%%~g"=="TAG:company_name" set "T_Company_Name=%%~h" if "%%~g"=="TAG:product_name" set "T_Product_Name=%%~h" if "%%~g"=="TAG:product_version" set "T_Product_Version=%%~h" if "%%~g"=="TAG:timecode" set "TIMECODE=%%~h" if "%%~g"=="width" set "V_Width=%%~h" if "%%~g"=="height" set "V_Height=%%~h" if "%%~g"=="sample_aspect_ratio" set "V_PAR=%%~h" if "%%~g"=="codec_type" if "%%~h"=="audio" set /a AUCount+=1 ) if "%V_Width%"=="" ( echo ERROR: Video Width NOT FOUND! pause goto :eof ) if "%V_Height%"=="" ( echo ERROR: Video Height NOT FOUND! pause goto :eof ) if "%V_PAR%"=="" ( echo ERROR: Video PAR NOT FOUND! pause goto :eof ) rem Set "V_Q=UD" rem if %V_Width% LEQ 1920 if %V_Height% LEQ 1120 \\ Set "V_Q=HD" rem if %V_Width% LEQ 1280 if %V_Height% LEQ 752 Set "V_Q=MD" if %V_Width% LEQ 1024 if %V_Height% LEQ 608 Set "V_Q=SD" echo Using %V_Q% Mode echo PAR = %V_PAR% if "%TimeCode%"=="" echo Warning! no TimeCode Found! if NOT "%TimeCode%"=="" echo Timecode= %TIMECODE% v:\automazioneclip\virtualdub\mediainfo.exe "%CD%\%~n1.mxf" dumpinfo:unicodefile.txt TYPE unicodefile.txt>ascii.txt ren ascii.txt mediainfo.txt findstr /c:"Codec ID : 0D01030102020201-0401020202010200" "mediainfo.txt" IF NOT ERRORLEVEL 1 (set "dvcam=1") CALL :Make_File "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1" echo FATTO echo. echo --------------------------------------------- echo. EndLocal goto :eof :Make_File <VCF_FILENAME> <AVS_FILENAME> <FILENAME> <ORG_FILENAME> rem *** TRY extract audio from .MXF IMX SD FILE *** Set "TokenS=0" IF "%~x4"==".MXF" Set "TokenS=1" IF "%~x4"==".mxf" Set "TokenS=1" If "%TokenS%"=="1" (if "%V_Width%"=="720" (v:\automazioneclip\core\ffmpeg.exe -loglevel fatal -y -i %4 -map_channel 0.1.0 -map_channel 0.1.1 -af "volume=volume=9dB:precision=fixed" "%DestFolder%\%~n1.wav")) If "%TokenS%"=="1" (if "%V_Width%"=="720" (v:\automazioneclip\core\ffmpeg.exe -loglevel fatal -y -i %4 -map_channel 0.1.2 -map_channel 0.1.3 -af "volume=volume=9dB:precision=fixed" "%DestFolder%\%~n1ch3ch4.wav")) rem *** TRY extract audio from .MXF XDCAM-HD 4:2:2 FILE *** Set "TokenS=0" IF "%~x4"==".MXF" Set "TokenS=1" IF "%~x4"==".mxf" Set "TokenS=1" If "%TokenS%"=="1" (if "%V_Width%"=="1920" (v:\automazioneclip\core\ffmpeg.exe -y -i %4 -filter_complex "[0:1] [0:2] amerge,volume=1.5" -c:a pcm_s16le "%DestFolder%\%~n1.wav")) If "%TokenS%"=="1" (if "%V_Width%"=="1920" (v:\automazioneclip\core\ffmpeg.exe -y -i %4 -filter_complex "[0:3] [0:4] amerge,volume=1.5" -c:a pcm_s16le "%DestFolder%\%~n1ch3ch4.wav")) rem *** TRY extract audio from .MXF OTHER TYPE *** Set "TokenS=0" IF "%~x4"==".MXF" Set "TokenS=1" IF "%~x4"==".mxf" Set "TokenS=1" If "%TokenS%"=="1" (v:\automazioneclip\core\ffmpeg.exe -y -i %4 -filter_complex "[0:1] [0:2] amerge,volume=1.5" -c:a pcm_s16le "%DestFolder%\%~n1.wav") If "%TokenS%"=="1" (v:\automazioneclip\core\ffmpeg.exe -y -i %4 -filter_complex "[0:3] [0:4] amerge,volume=1.5" -c:a pcm_s16le "%DestFolder%\%~n1ch3ch4.wav") rem *** TRY extract audio from GOPRO MP4 file *** Set "TokenS=0" IF "%~x4"==".MP4" Set "TokenS=1" IF "%~x4"==".mp4" Set "TokenS=1" If "%TokenS%"=="1" (v:\automazioneclip\core\ffmpeg.exe -y -i %4 -filter_complex "[0:1] volume=1.5" -c:a pcm_s16le "%DestFolder%\%~n1.wav") rem *** TRY extract audio from .MP4 OTHER TYPE *** Set "TokenS=0" IF "%~x4"==".MP4" Set "TokenS=1" IF "%~x4"==".mp4" Set "TokenS=1" If "%TokenS%"=="1" (v:\automazioneclip\core\ffmpeg.exe -y -i %4 -filter_complex "[0:0] volume=1.5" -c:a pcm_s16le "%DestFolder%\%~n1.wav") echo *** from various format to MorganMJPEG AVI SD 720x576i@25fps *** rem ***Make The .vcf Script File*** echo VirtualDub.audio.SetSource^(0^)^;>%1 echo VirtualDub.audio.SetMode^(0^)^;>>%1 echo VirtualDub.audio.SetInterleave^(1,500,1,0,0^)^;>>%1 echo VirtualDub.audio.SetClipMode^(1,1^)^;>>%1 echo VirtualDub.audio.SetEditMode^(1^)^;>>%1 echo VirtualDub.audio.SetConversion^(0,0,0,0,0^)^;>>%1 echo VirtualDub.audio.SetVolume^(^)^;>>%1 echo VirtualDub.audio.SetCompression^(^)^;>>%1 echo VirtualDub.audio.EnableFilterGraph^(0^)^;>>%1 echo VirtualDub.video.SetInputFormat^(11^)^;>>%1 echo VirtualDub.video.SetOutputFormat^(11^)^;>>%1 echo VirtualDub.video.SetMode^(1^)^;>>%1 echo VirtualDub.video.SetSmartRendering^(0^)^;>>%1 echo VirtualDub.video.SetPreserveEmptyFrames^(0^)^;>>%1 echo VirtualDub.video.SetFrameRate2^(0,0,1^)^;>>%1 echo VirtualDub.video.SetIVTC^(0, 0, 0, 0^)^;>>%1 echo VirtualDub.video.SetCompression^(0x6a6d7674,0,10000,0^)^;>>%1 echo VirtualDub.video.SetCompData^(28,"TUpQRxgAAAAAAAAAAgAAAAgAAAACAAAAAQAAAA=="^)^;>>%1 echo VirtualDub.video.filters.Clear^(^)^;>>%1 echo VirtualDub.audio.filters.Clear^(^);>>%1 if NOT "%TimeCode%"=="" echo VirtualDub.project.ClearTextInfo^(^)^;>>%1 if NOT "%TimeCode%"=="" echo VirtualDub.project.AddTextInfo^("ISMP", "%TIMECODE%"^)^;>>%1 echo VirtualDub.SaveAVI^("%DestFolder%\\%~n1_SD.avi"^)^;>>%1 echo VirtualDub.Close^(^)^;>>%1 rem ***Make The .avs Script File*** echo FFVideoSource^(%4^)>%2 echo ConvertToYUY2^(interlaced=true^)>>%2 if "%dvcam%"=="1" echo ReverseFieldDominance^(^)>>%2 echo src = last >>%2 echo src = src.width==720^&^&src.height==608?src.crop^(0,32,0,0^):src >>%2 echo src = src.width^>720 ^|^| src.height^>608?src.ColorMatrix^(mode="Rec.709->Rec.601"^): src >>%2 echo src = src.width!=720 ^|^| src.height!=576 ? src.IResize^(720,576^): src >>%2 echo function IResize^(clip Clip, int NewWidth, int NewHeight^) {>>%2 echo Clip>>%2 echo SeparateFields^(^)>>%2 echo Shift=^(GetParity() ? -0.25 : 0.25) * ^(Height()/Float(NewHeight/2)^-1.0^)>>%2 echo E = SelectEven^(^).Spline36resize^(NewWidth, NewHeight/2, 0, Shift^)>>%2 echo O = SelectOdd^( ^).Spline36resize^(NewWidth, NewHeight/2, 0, -Shift^)>>%2 echo Ec = SelectEven^( ^).Spline36resize^(NewWidth, NewHeight/2, 0, 2*Shift^)>>%2 echo Oc = SelectOdd^( ^).Spline36resize^(NewWidth, NewHeight/2, 0, -2*shift^)>>%2 echo Interleave^(E, O^)>>%2 echo IsYV12^(^) ? MergeChroma^(Interleave(Ec, Oc)^) : Last >>%2 echo Weave^(^)>>%2 echo } >>%2 echo AssumeTFF^(^)>>%2 echo SeparateFields^(^)>>%2 echo Ev=SelectEven^(^).sharpen(0.20^)>>%2 echo Od=SelectOdd^(^).sharpen^(0.20^)>>%2 echo Interleave^(Ev,Od^)>>%2 echo Weave^(^)>>%2 echo src.framerate^<26 ? src:src.AssumeTFF^(^).SeparateFields^(^).SelectEvery^(4,0,3^).Weave^(^) >>%2 echo AssumeFPS^(25^)>>%2 echo ChangeFPS^(25^)>>%2 echo processing source file %4 rem ***Call VirtualDub*** if NOT EXIST %VD_LOC% ( echo Um, where the hell is VirtualDubMod? pause ) %VD_LOC% /min %2 /s %1 for %%v in ("%DestFolder%\\%~n1_SD.avi") do ( if %%~zv LSS 128 ( echo ERROR!!! Extra Small File Size Detected!!! pause ) ) v:\automazioneclip\virtualdub\cfourcc.exe -i "%CD%\%~n1_SD.avi" -u MJPG -d MJPG DEL "%DestFolder%\*.ffindex" DEL "%DestFolder%\*.VCF" DEL "%DestFolder%\*.avs" DEL "%DestFolder%\ascii.txt" DEL "%DestFolder%\unicodefile.txt" DEL "%DestFolder%\mediainfo.txt" goto :eof :GetTargetName Set "FileName=" Set /p FileName=InputFileName .mxf .mp4 or .avi or InputFolder - INVIO per convertire tutto (EXIT esce): rem Add or remove double-quotes if necessary if NOT DEFINED FileName ( Set "FileName-DQ=" goto :DQSkip ) Set "FileName-DQ=%FileName:"=%" if NOT DEFINED FileName-DQ ( Set "FileName=" Set "FileName-DQ=" goto :DQSkip ) if EXIST "%FileName-DQ%" ( if "%FileName-DQ%"=="%FileName-DQ: =%" ( Set "FileName=%FileName-DQ%" ) else ( Set FileName="%FileName-DQ%" ) ) :DQSkip if /I "%FileName-DQ%"=="" Set FileName="%CD%" if /I "%FileName-DQ%"=="CD" Set FileName="%CD%" if /I "%FileName-DQ%"=="EXIT" goto :eof if /I "%FileName-DQ%"=="NOEXIT" goto :GetTargetName if DEFINED FileName ( Set /a ARGLVL+=1 CALL :ARGS %FileName% Set /a ARGLVL-=1 ) goto :GetTargetName
